300ZX Brake Swap Complete
Old Mar 11, 2005 | 07:29 PM
  #41
z32drifter's Avatar
Matt will the 04 Max rotor work with the 26mm Z caliper ??
Old Mar 12, 2005 | 06:05 AM
  #42
hiphipmaxima's Avatar
matt quick question will G35 brembo calipers work
Old Mar 12, 2005 | 07:03 AM
  #43
Matt93SE's Avatar
STFU n00b!
No, and No.
these kits are designed for this speficic caliper and dimension in mind. change anything else out and they don't fit.
Old Mar 12, 2005 | 07:46 AM
  #44
alrighty thank you very much for the info also, MATT that kit that you have for $700.00 what does that include? front and rear or just the front?
Old Mar 12, 2005 | 10:42 AM
  #45
z32drifter's Avatar
Originally Posted by Matt93SE
No, and No.
damn these free 26mm Z brakes
Old Mar 13, 2005 | 02:22 AM
  #46
eturnl
Originally Posted by jblinga
... the main reason I did this swap is my stock calipers sucked(installed new rotors and I still had vibration in the pedal, this is common in all stock maxima calipers, my girlfriends' 5th gen has only 50K and it has the same problem). After replacing stock calipers w/300ZX calipers, this vibration is finally gone!
I had no idea that pedal vibration can be due to calipers!? are you serious?! that sucks. that means after i change my pads and rotors, (hoping vibrations are all gone) i might have to go back and change my callipers afterwards as well? poo! but thats for the info!
Old Mar 13, 2005 | 10:14 AM
  #47
MaximaSE96's Avatar
Maxima Owner
Originally Posted by MAXRB8
Let me get this straight, 300ZX rotors bolt on directly with 300ZX stock rotors to our Maxima's along with steel brake lines (240sx to 300zx ebay). Is there a difference between 300ZX TT and NA rotors?
And if you want to go to 13" cobra rotors jeff92se sells conversion brackets?
Hey Jeff do you sell the any kits minus the calipers?
This looks like it kicks *** on other big brake kits on a cost factor.
I used to have a 300ZXTT and the braking was awesome, can anyone answer these questions?? thanks
u need the brackets off the 300zx too.....he prolly had them....most people here onlyhave access to the calipers not the brackets so thats y they need all the hardware from Jeff......so as in my case i have access to the rotors calipers and brackets so all i am going to need is the brake lines....
Old Mar 13, 2005 | 10:34 AM
  #48
MaximaSE96's Avatar
Maxima Owner
Remanufactured 91' 300ZX TT front calipers 220$ after core credit from stock calipers Centric Parts Calif.
300ZX TT brembo cross-drilled rotors 154$ shipped ebay
240SX-300ZX conversion stainless steel brake lines 70$ shipped ebay
Brute stop raybestos pads 52$ checker auto
60$ to machine rotors down 6mm off the diameter Local machine shop
556$ total, not bad for four piston calipers, cross-drilled brembo rotors & stainless steel brake lines
is that 6mm per rotor or 3 per rotor= 6 total
to be machined off that is
Old Mar 13, 2005 | 05:35 PM
  #49
jblinga's Avatar
6mm per rotor
Old Mar 13, 2005 | 05:36 PM
  #50
jblinga's Avatar
your promblem may not be the same, but it is possible.
Old Mar 13, 2005 | 10:38 PM
  #51
vsamoylov
only if i knew where to get some brembo rotors and calipers from a g35c or a 350z from.
Old Jul 2, 2007 | 01:31 AM
  #52
TorridoMax's Avatar
ok im bringing this oldie back.. any updates on this setup? also anyone have ideas on where i can get everything i need?
Old Jul 2, 2007 | 09:35 AM
  #53
Grave Digger,
You get the rings and brackets from Jeff92se, the rest you get on your own. You need to peek your head in the suspension and braking forum and start reading the stickies.........All of it is explained and then some.
Edit: You're vague on describing what you're trying to do. There are many different configurations. Read the Stickies as stated above.
Old Jul 2, 2007 | 10:10 AM
  #54
nexgenmax's Avatar
R34
http://importnut.net/300zxbrakeswap.htm
Old Oct 29, 2007 | 04:08 PM
  #55
DizzyEdge's Avatar
What does that mean?
This may identify me as a total newb, but if your Max has ABS, does that affect the feasiblity of this project?
Old Oct 30, 2007 | 05:27 AM
  #56
Dasyce's Avatar
Not at all. if you look in the classifieds there many people selling the entire kit.
Old Oct 31, 2007 | 01:31 PM
  #57
ThurzNite's Avatar
http://www.mattblehm.com/brakes.htm
BTW, to anybody wondering, get the rear brakes, they're essential and awesome.
Jae
Old Oct 31, 2007 | 01:42 PM
  #58
DizzyEdge's Avatar
Good, the guy I bought my old junker 91 max from said he had put on 300zx brakes.. and I thought he was bs'ing.. but this 96 GLE I just got definately has weaker braking than that 91! Could be other things I supposed though.
mvm062
Nov 30, 2020 09:00 AM
BkGreen97
Apr 2, 2016 05:47 AM
markevans999
Sep 10, 2015 04:29 PM
I<3 A32's
Sep 10, 2015 11:07 AM
crazyespn
Sep 3, 2015 01:30 PM
