HELP- Need to Get Door Panel Inserts OUT!!!!!!!!!!!!!!
I was looking at my tan door panels(cloth) and the insert i wanted to swap for leather, blah blah blah I was wondering if there was a way i could take these out without breaking them, It seems like they are in there pretty good!!
Help
Write-ups and suggestions would be nice!
Help
pull off the door panel and they come out very easy. take out the window switch, the little "holder" thing for you fingers ( its to hold onto when you close your door or open, dont know the real name) and there are two screws on the bottom of the door panel, very easy. you must pop off the trim around the inner door handle too. it comes off if you pull it either to the left and pull or to the right, its been a while. it will take you 5 mins. good luck
i used a flat head screw driver to put in and pull up enough to rip the rest out by hand. came out in one solid piece and wasn't hard at all. i then cut the holes in the appropriate place so the tabs on the back of the leather inserts could go in. then, you pull them tight and it's on there. just take your time and it comes out fine. took me 25 mins per panel total.
edit, sorry this is for the cloth insert only...
trsandrew
04-08-2016 06:45 PM
magiconthetire
10-26-2015 09:03 PM
trsandrew
10-25-2015 02:47 PM
REDinLV
10-18-2015 05:31 AM
