City Lights instructions please!
Old Mar 8, 2005 | 11:04 PM
5Zpeed's Avatar
I looked in the how to's section and I clicked on the link and the instructions aren't there anymore. Can someone please post them here? Thanks!
Old Mar 9, 2005 | 05:18 AM
nupe500's Avatar
Jedi Knight
I don't think there is a set way that they must be done. Can I suggest that you use google?
Old Mar 9, 2005 | 07:01 AM
meanbean's Avatar
This mod is pretty much staight forward. Some have used 194 bulbs while others have used 5mm LEDs for this mod. First, you will need to drill the appropriate hole or holes into the headlight. I find it easier to first open the headlight via the oven method so that clean up is easy. Next, attach the bulb holder and glue it or mount it in place. Mine are mounted on the top of the headlight so they are not visible unless looking directly at them from the ground. I glued/sealed them using silicon glue. It's been over 1.5 years and I have no problem with condensation. Finally, wire the light to a SPST switch powered by the battery or use a relay to control the power when parking lights are turned on. There are numerous ways to go about powering the city lights so choose a method that suits your application. Here is a pic of my LED city light retro. As always, take your time and have fun modding.
Old Mar 9, 2005 | 08:43 AM
HomerMAC's Avatar
Donating i30 Owner
damm u mean bean and ur FLIPPIN GUAGES.. how did u get htem like that.. TELL ME NOWWW>> please sir..
yea jus tput in little bulb inot the housing. pref in the coner.. lower inner part of the housing...
also.. this city light method can be used if anyone plans on HIDing in the stock housing.. u can dill in a Fog light bulb below the shield.. in teh lower part of light housing.. and when that lights up the lower par lights up the housing for the highbeam..
Old Mar 9, 2005 | 09:53 AM
MaxKlinger's Avatar
Can someone take a step back for a second and define what "city lights" are?
Thanks.
Old Mar 9, 2005 | 11:31 AM
MaDMvD's Avatar
Thanks.
I second that!
Old Mar 10, 2005 | 06:20 AM
meanbean's Avatar
I am now using 84 red 5mm 14000mcd LEDs and 2 6" UV CCFLs to light the gauges and needles. The high number of LEDs used was to provide an even level of lighting and prevent spot lighting normally caused by LEDs. The LEDs are wired to power on automatically when parking lights are on and the CCFLs are wired to a SPST switch to be powered on independently. The needles have been sanded down from the bottom to give the glow effect. This mod is very time consuming and requires the use of a soldering iron and dremel. I will not cover how to go about performing this mod since it is difficult to describe wiring, placement and aiming of the LEDs. If you have a fair level of knowledge on LEDs and resistors then you will be able to discern the process fairly quickly. The majority of time spent on this project will be on aiming the LEDs to evenly light your guages.
This should be fairly intuitive. City lights are lights that provide your headlights with the appearance of being on without the output normally provided by your normal headlight bulbs. They are to be used at night while driving through well lit city streets. Hence, the name city lights. IMHO, this is more of a bling mod and has no real/practical benefit.
Old Mar 10, 2005 | 06:27 AM
MaDMvD's Avatar
That's just insane.
Old Mar 10, 2005 | 07:31 AM
HomerMAC's Avatar
Donating i30 Owner
... 84.. leds.. wow.. ur an animal...
Old Mar 10, 2005 | 08:59 AM
meanbean's Avatar
You can decrease the number of LEDs needed if you get ones that have a wider viewing angle. The ones I used were only 10°. Usually, the wider viewing angle LEDs tend to cost more so there will be a trade off. Try what ever number you like and see if it lights up to your expectations. If not, then keep adding more until it does. This mod is tailored to the owner so there is no correct way to go about completing it.
fastcarny
Oct 6, 2015 10:42 AM
rnb754
Sep 14, 2015 11:39 PM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
