Center air vent removal.
Old Mar 12, 2005 | 12:16 PM
Sky_99's Avatar
Hey, I'm in the middle of taking the dash apart so that I can install my new headunit. I'm having the hardest time trying to "pry" out the center air vents. If anybody has any tips or tricks, they'd be VERY appreciated. If I keep going at this I'm guaranteed to break something.
Old Mar 12, 2005 | 12:26 PM
sunten1
usally i pop it up form the bottom...like were the ac contorls are...and the when i can fit a couple fingers in there i push from the top of the vents down and it usally comes out..
Old Mar 12, 2005 | 12:28 PM
Black Maxima
Put a flat blade screwdriver in the crack between the airvents and AC Unit. Pry the vents up. There are two tabs for the vents you need to un-hook (on the bottom). Once the lower part of the air vent piece pops out pull it down and towards you at the same time. You might want to stick a screw driver in the tops of the vents to help you. Hope that helped.
Don't get intimidated by the wire/plugs connected to the back of it. Just shove a flat screwdriver into the tabs on the plug and pull the wires.
Old Mar 13, 2005 | 06:01 AM
Sky_99's Avatar
Thanks for the tips guys. I went back at it with the screw drivers and got the pos out of there. I wasn't really worried about damaging the wiring or the vents, but I'd be pissed if I marred the dash.
Old Mar 13, 2005 | 06:06 AM
Conrad283's Avatar
I need a truck
The first time mine was taken out, he said "It's going to sound like it's breaking, but it's not." Real reassuring. Now it comes out like a piece of cake.
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
gigabyte
Jan 6, 2017 06:05 PM
Justin Kroll
Oct 1, 2015 07:03 PM
MichMaxFan
Sep 30, 2015 09:18 AM
