Help......!!!
Old Mar 21, 2005 | 01:20 PM
maxtuner96's Avatar
Help......!!!
Driving to work this morning, I noticed my brake light & battery light both came on at the same time. This happened less than 5min from leaving my house. I checked to battery terminals to see if anything became disconnected, and I also went to autozone and checked the codes with their scanner (No Codes Found). The brakes feel the same and nothing seems to be wrong with the charging system. What's should I do next?
Old Mar 21, 2005 | 01:23 PM
DAVE Sz's Avatar
Hooooooonda.....
Alternator probably, maybe low on brake fluid, weak battery, maybe all that pointless stereo stuff had something to do with it?. Next time you start a thread, say what it's about in the title.
Old Mar 21, 2005 | 01:38 PM
mbandi's Avatar
Da'Burgh, Go Stillers!
Most likely alternator. Your max is wired for both lights to come on when charging voltage is to low. Have your charging system checked.
Old Mar 21, 2005 | 02:38 PM
KCMaxima98's Avatar
Definitely alternator. If the car is still running, it won't be for long.
Old Mar 21, 2005 | 02:49 PM
maxtuner96's Avatar
Dammn!......The alternator I have right now has only been in since December....It does have a lifetime warranty though...If that's deffinitely the problem, it shouldn't cost me anything. Thank you for all in info guys.
Old Mar 21, 2005 | 05:50 PM
sunysb83's Avatar
hmmm, thats pretty quick for an alternator to die in four months, check your belts too, make sure nothing is loose.
Old Mar 21, 2005 | 09:02 PM
maxtuner96's Avatar
Oops...I got my "embers" mixed up....It was late Sept-ember when I replaced the alternator. But, that still wasn't that long ago.
Old Mar 21, 2005 | 09:47 PM
MDeezy's Avatar
check your break fluid and test your battery with a multimeter. if those are fine get alternator tested.
Old Mar 21, 2005 | 10:17 PM
maxtuner96's Avatar
I just checked the brake fluid and the level is fine. I also checked each and every fuse (all ok)...Tried the "disconnect the negative batter terminal while the car is running" trick and the car DIED....so...now the only thing to do IS replace the alternator....AGAIN
Old Mar 22, 2005 | 05:16 AM
nosispower's Avatar
Tough luck man, when I bought my 1997 SE, the dealer replaced the alternator ebcause the same xact thing was happening. I just hope mines lasts a little longer than 6 months.
Old Mar 22, 2005 | 05:46 AM
larryseibel's Avatar
it is not unusual for the brake light to come on in a low voltage situation. replace the battery or alternator...whichever one is bad will fix both lights.
Old Mar 22, 2005 | 05:56 AM
HOMERUN4THGLE's Avatar
Definitely the alternator I am working on my third in four years. That is the way my car usually signals its death.
Old Mar 22, 2005 | 08:19 AM
maxgtr2000's Avatar
KH3 by popular demand
There was a recall on Maxima alternators a while back, it may have only been for 97s though, if not its something to check into to get it replaced for free.
shnken
Oct 23, 2017 01:40 AM
Twokidsandadad
Mar 27, 2013 10:20 AM
vdesosa
19
Jan 21, 2013 07:02 PM
vqmaxman
May 21, 2009 10:49 PM
alex9696
Mar 25, 2003 09:58 PM
