Intake Adapter
Old Mar 23, 2005 | 10:24 AM
jif718's Avatar
Intake Adapter
Anyone know where I can get an intake adapter in brooklyn?
I need one that is similar to
http://images.andale.com/f2/130/127/...0AirFilter.jpg
and will fit a K&N 4" Filter.
The inlet is 3"
http://www.knfilterchargers.com/sear...x?Prod=RU-2520
Old Mar 23, 2005 | 12:18 PM
mzmtg's Avatar
Minister of Silly Walks
You can make one out of your stock airbox.
If you look inside the airbox, there's a gold piece with a flare that extends into the box. Drill out the rivets and bolt that directly to the MAF. Then strap the filter to the gold piece. Be careful not to bend the gold piece and make sure you seal any gaps between it and the MAF.
Old Mar 23, 2005 | 12:29 PM
jif718's Avatar
the gold piece is 3" circumference, the filter I have is 4"... the whole damn gold thing falls thru into the cone filter lol
Old Mar 23, 2005 | 12:33 PM
mzmtg's Avatar
Oh, I thought you said it had a 3" inlet...
Old Mar 23, 2005 | 12:35 PM
jif718's Avatar
http://i152.exs.cx/img152/3159/filter3uy.jpg
the red is the circumference of my filter
yellow is the gold adapter circumference..
Old Mar 23, 2005 | 03:17 PM
nismos14's Avatar
§è~® f®ÈÄk
well the the filter's inlet is 4 inches then.
Old Mar 24, 2005 | 04:37 AM
jif718's Avatar
is there an adapter that'll connect as 3" and convert to 4"
Old Mar 24, 2005 | 08:21 AM
95BLKMAX's Avatar
Kind of guetto, but maybe you can make it work. Go to a local parts store (if not, a muffler shop) and look for an exhaust reducer from 4" to 3". I dont know if they even make them at 4" diameter, but you never know. Give it a try if all else fails. Check Home Depot as well, maybe they have something similar for plumbing.
Old Mar 24, 2005 | 08:30 AM
Jar's Avatar
Jar
I was told the same thing from a local parts store when I was putting mine together, if you cant get something from a muffler shop, try (and yes it sounds bad) black water pipe from a home improvement store (home depot, lowes, or jerrys and fred meyers even) should work just fine for an intake.
magiconthetire
Oct 26, 2015 09:03 PM
maxima297
Sep 30, 2015 03:32 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
MichMaxFan
Sep 30, 2015 09:18 AM
