White LEDs not comming out so white in gauges and shifter?
Old Mar 24, 2005 | 06:46 PM
D1NOnly34's Avatar
So I bought white LEDs to put behind my gauges and shifter. I had blue LEDs before and they came out awesome, but when i put my white ones in, they werent as white as i expected. I tested them out on the door lights to see if it was the LED that had miscoloration, and they were pure white. I had an extra auto shifter plate around here so I took it apart and to my surprise I found out that under the letter/numbers for the gears, there is like some kind of blue layer of film or something of the sort, nothing that I can really take out. Is there any way to get rid of that layer so that the light shines pure white? I'm assuming that the same goes for the gauges cause I'm getting the same kind of reponse from the LEDs. i'll try and take a picture of the shifter plate later so you can understad what i'm talking about.
Old Mar 24, 2005 | 06:50 PM
LowProfile's Avatar
i think i know what you mean, i recently tried to put in white led's in my gauges but they don't have enough brightness. I was only successful in making the needles white. Anywayz, you are better off getting polarg or piaa 194's (non-LED) types for gauge or shifter lighting.
Old Mar 25, 2005 | 12:09 AM
wariow's Avatar
there's a blue tint behind the numbers so you'll never get a pure white anyway.
Old Mar 25, 2005 | 01:13 AM
Maxima_Joe's Avatar
4th Gen Parts King
I have not found a better bulb for the shifter. for the gauge the best i have found were piaa extreme white or polargs 194
Old Mar 25, 2005 | 06:44 AM
D1NOnly34's Avatar
yeah but ure gauges look real good, they look prety white to me, what bulbs did you use?
Old Mar 25, 2005 | 06:51 AM
maximusprimus's Avatar
Leds Are Not Suppose To Be Bright , They Are Bright If They HAVE Reflectors Around Them Like Spoilers
Old Mar 25, 2005 | 05:47 PM
D1NOnly34's Avatar
ok true, im not really concerned on the brightness, just the color output after being installed
Old Mar 25, 2005 | 06:28 PM
G4nismo's Avatar
yeh see, i used xenon white and ended up bluish. but i'm not complain cause i luv blue
Old Mar 25, 2005 | 06:53 PM
Max Mutes's Avatar
Yes, Wariow is right. There's a Blue VHT behind the Black Gauges. If you use a regular White LED, it will show up blueish/maybe even purplish. I recently threw in Polarg M4's and I have no problems with a hint of blue whatsoever. The Speedo Gauge sometimes is a fairly light pink...but after a min or 2 of warming up it goes right to bright white.
Here's Pics (please excuse Camera Phone):
PS: That Blue hinted Gauge section is a WHITE LED from Superbright LED's. Goes to show you exactly what we mean about the Blue VHT behind the gauges.
Old Mar 27, 2005 | 09:28 AM
D1NOnly34's Avatar
is it the same for those who have the factory white face gauges? where can i get those polarg m4s?
Old Mar 27, 2005 | 10:16 AM
sunten1
ebay...-> http://search.ebay.com/polarg_W0QQfr...opZ3QQsbrsrtZl
so polarg is the way to go for white gauges???
D1Nonly34- how did you take apart the shifter...i can never figure it out...is ther a write up?
Old Mar 27, 2005 | 12:30 PM
D1NOnly34's Avatar
if you already have it out of your car, the shifter is basically 2 main peices, getting a small flathead screw driver and pry the 2 peices form each other, try not to break it =)
Old Mar 27, 2005 | 01:54 PM
Black Maxima
Hey sunten1, I'll do your shifter light at the next Maxima Meet.
Fakie J Farkerton
Oct 14, 2015 06:25 PM
Max8
Aug 20, 2015 07:20 PM
spidgeon
Aug 18, 2015 05:46 AM
acw
Aug 13, 2015 12:50 AM
