Calling all Nissan Techs......
Free....
I have a 1996 Max with 109,000 miles and I have two problems:
1-I am getting a bad fuel smell after I get gas inside the cabin. Any idea what could be causing it?
2-When I put my car in reverse a give it gas it stalls, but if I put the car in reverse and just let it roll on it's own no problems. Any ideas?
2) fuel filler neck could be damaged or corroded.
you are smelling gas from a your gas lines around your fuel filter...they are rubber and expand and contract with age. Pick youself up a new fuel filter and some new rubber lines youll be straight....a good self diagnosis is to know when the gas smell is more prevalent...if it is more on colder days then bingo! its the gas lines
as far as putting the car in reverse....Im not sure..tough to diagnose with such a vague description...does matter of the car is warm or not....is it consistent or inconsistent (does it only stall in reverse sometimes?)
2-It only stalls in reverse pretty much all the time no matter what the temp is. It only does it when I acellerate in reverse.
Originally Posted by CaLSoNiC
do you close your doors/windows while fueling? when was the last time your replaced your fuel filter/injectors?
the reverse problem happened with my 280zx. the air filter was really dirty (totally blocked) so when trying to go in reverse there was no positive air flow, but when i went forward it was fine, just a little boggy. this was a pretty unique experience for me so it may or may not be anywhere close to what your problem is.
Would the crankshaft sensor throw a code cause I don't a "check engine" lite on?
So check your codes and use that as a starting point.
Dave
Justin Kroll
09-02-2015 11:06 AM
