Rattle while stopped in D!!
When I am stopped at a light or something and I have my car in "D" there is a rattling noise coming from my dash, when its in neutral the noise goes away and when I start to pull off the noise goes away... I saw a post about this a few days ago, but could no find it, anyone know what this is?????
There is a TSB about this. Its the hardline for the brake assist. Pull the hardline out of the clips and wrap hockey tap around the contact points. Or do away with the hardline alltogether by finding some correct size tubing.
You will have no adverse effects except your level of sanity if you leave it alone. It is the brake assist line. The brake master cylinder uses the vacum developed by the engine in the IM to require less force be applied to the brake pedal. If you want see what it does disconnect it. The braking force required will be much higher.
There is a check valve that can fail. There is a Brake Trouble shooting section in the FSM. I'll sum it up. The Brake assist uses engine vacum to supplement pedal effort. When the system is working properly it will open after any braking to allow vacum into the system again. A simple way to check is: Get going on an open road. At least 50. Turn the car off while still coasting at speed. Hit the brakes then release. The pedal should have felt normal. Then hit the brakes again. This time it should be much harder to push the pedal. If there is no difference between the first brake and second or if the difference was miniscule you have a faulty system and should look into that before you die.
Originally Posted by jtm087
Hold on so you turn your car off while your coasting at 50 and still in Drive??? Is that safe I mean there aren't too many open roads where you can just go a clean 50 and not have any traffic around you
Apr 16, 2020 05:15 AM
maxima297
Sep 30, 2015 03:32 PM
