Just Came back from the Dyno. :)
Old Mar 27, 2005 | 01:32 PM
  #41
DandyMax's Avatar
3.5 in the works
Hmm. Ok. Maybe it just looks different to me in the pic -- I just seemed to remember the color/coating of my y piece looking different...
Anyways, nice dyno #'s, hope mine turn out similarly.
Old Mar 27, 2005 | 02:44 PM
  #42
I30tMikeD's Avatar
Cattman started using a different coating on the manifold then the y-pipe. It sis all still ceramic coated just with two different types
Old Mar 27, 2005 | 02:47 PM
  #43
Jason R's Avatar
aka UNCDooD
wow i want a full Cattman exhaust too. I bet it sounds too nice. I wonder what kind of power I'm putting down now. it may be time for another visit to the dyno.
Old Mar 27, 2005 | 03:06 PM
  #44
VeeQueue's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Not only is the color different, the pipes are physically different in my case. Check the length of the flex joint and the location its placed between Optimus310's to mine.
Optimus310
Mine
I got mine after his GD.
Old Mar 27, 2005 | 03:51 PM
  #45
Maximeltman's Avatar
cattman so yes it must've
Old Mar 27, 2005 | 04:34 PM
  #46
I30tMikeD's Avatar
Optimus310
Mine
Mine were like yours. I think it was just a longer flex section and the different ceramic coating. Same technical design just a few tweaks.
Old Mar 27, 2005 | 05:34 PM
  #47
laylow1988's Avatar
Originally Posted by vsamoylov
must have cost a preety penny right?
you mean a pretty couple of quarters. that thing is like $750+
Old Mar 27, 2005 | 05:58 PM
  #48
vsamoylov
and torque moves the car not horsepower.
Old Mar 27, 2005 | 06:05 PM
  #49
scrhale's Avatar
I know MEVI loses power on our cars from low to mid range put helps with high end. Does 00VI do the same or is it actually better through the entire power band.
Old Mar 27, 2005 | 10:18 PM
  #50
I30tMikeD's Avatar
You don't know jack
Old Mar 27, 2005 | 10:20 PM
  #51
Nismo3112's Avatar
Custom User Title
I thought the tires moved the car
Old Mar 27, 2005 | 10:22 PM
  #52
vsamoylov
Originally Posted by I30tMikeD
You don't know jack
want to let me know then?
Old Mar 27, 2005 | 10:41 PM
  #53
I30tMikeD's Avatar
Sure torque moves the car, but it is not the only part of the equation. The given rpm that the torque occurs is what is important and that is what HP comes from. So at mid lower rpm's alot of toque is what matters since the rpm's are not high enough to create as much HP. The car accelerates along the HP curve, the torque curve just creates the HP curve.
Looking at the dyno graph in this thread you would want to shift where you would stay in the power band the longest period of time...in other words what part of the power band does the most power ((torque X rpm)/5250) occur over about a 2K rpm span? If you were to shift at 5200 rpm's like you suggested then the car would fall back to 3.2K rpm's and have no power. But if yo were to shift at say 6.3K rpm's then you would fall right back into the heart of the power band, 4.3K rpm's.
A general rule of thumb is to shift 500 rpm's past peak HP
Old Mar 27, 2005 | 11:20 PM
  #54
vsamoylov
do you know by any chance how much revs you fall back when you shift?
Old Mar 28, 2005 | 04:23 AM
  #55
I30tMikeD's Avatar
Old Mar 28, 2005 | 06:42 AM
  #56
NmexMAX's Avatar
dot dot dot ...
Rpm = mph x gear ratio x 336/Tire diameter
Rough estimate would be from this equation, reason it's rough is b/c the car is still moving foward between shifts, obviosuly, so then the next gear rpm will be higher than this equation suggests.
On a sidenote, VeeQue, mine look like yours, (they were I30MikeD's) and they are now on a 5.5g. I get a slight rattle from 2.5-2.8k someitmes, thinking it could be from tht weird bend ... not sure.
Old Mar 28, 2005 | 07:03 AM
  #57
theshawn's Avatar
the Light is among you
Nice dyno, especially considering it was done at 88 degrees. I'll bet it could have posted slightly higher in cooler temps. Purrty head/ypipe section too.
Old Mar 28, 2005 | 07:05 AM
  #58
Conrad283's Avatar
I need a truck
Damn, those are some sweet numbers. Any more plans?
Old Mar 28, 2005 | 07:11 AM
  #59
NmexMAX's Avatar
dot dot dot ...
That's what the correction factor is for,. 1.04 ... So essentially it was like he was at ideal temps, rather than 88*
Old Mar 28, 2005 | 11:39 AM
  #60
I30tMikeD's Avatar
I had a buzzy type noise at the same rpm's. Put some heater wrap around the flex section and it took most of it away. But I did not want to rust out the flex so I took it off after a few weeks and just lived with the noise, but it really wasn't a big deal though
Old Mar 28, 2005 | 11:51 AM
  #61
NmexMAX's Avatar
dot dot dot ...
Since I have stock cat-back, it's not noticeabele at all, only if your ears are specifically tuned for stock 5.5g Maximas, come to think of it, I forgot how it sounded when it was stock compared to now. Those things helped out tremendously, my first drive, I was amazed, has a hard time keeping traction when flooring it mid -gear in 1st, and that's that I'm at anywhere between 5500'-7400'.
Old Mar 28, 2005 | 01:40 PM
  #62
Y2KSESteve's Avatar
Nice numbers Danny! I need to get on the dyno asap..
markevans999
Sep 10, 2015 04:29 PM
Maxima30
Sep 7, 2015 06:13 PM
GregL65
Sep 5, 2015 09:37 PM
crazyespn
Sep 3, 2015 01:30 PM
