what should i clean/fix etc after long use?
Old Mar 27, 2005 | 11:52 AM
mrgreek's Avatar
hey guys...
i got 255km on it,
first id like to say that we got a 96 maxima that my dad bought in 96 and we've only changed knock sensor, brakes, tires, o2 sensor, oil,sparkplugs and thats it believe it or not...on a full tank of gas i just completed 375-390 miles, mostly highway but city too, im guessing that aint bad? this is why i love my maxima, it takes abuse and it doesnt play games with me
so i wanna ask u guys, wat should i do to my maxima? replace air filter, fuel filter, (im replacing absolute pressure sensor), change oil, clean throttle body, after these processes, should my maxima be all swell? god damnit it deserves it lol
any other things u guys got to suggest?
also, is this the where the fuel filter is located?...
thnx in advance guys
Old Mar 27, 2005 | 11:55 AM
MAXRB8's Avatar
Clean your IAC valve!
Old Mar 27, 2005 | 12:01 PM
MaDMvD's Avatar
The fuel filter is located at the very back of the engine bay, I'd say behind the throttle body. It is attatched to a clamp that holds it in place. I'll try to find the write-up I used..
Old Mar 27, 2005 | 12:10 PM
tavarish's Avatar
fwd gone rwd cr00
your VQ needs a bath....badly
Old Mar 27, 2005 | 12:11 PM
mrgreek's Avatar
i updated the pictures, lol, wats vq? ur dealing with me, a big noob here
Old Mar 27, 2005 | 12:22 PM
MaDMvD's Avatar
VQ = VQ30DE, your engine.
Old Mar 27, 2005 | 12:39 PM
my99maxisnice's Avatar
So does this mean in 9 years you've never replaced the air or fuel filter?
Old Mar 27, 2005 | 12:47 PM
Sy0p's Avatar
that is the dirtiest engine bay i have ever seen on a maxima that poor car, sir you deserve a slap for treating her like that .
Old Mar 27, 2005 | 12:53 PM
mrgreek's Avatar
yes, to both last replies i havent replaced any of them
im doing all that stuff this coming weekend...i didnt look after it, my dad did, and my dad has never had problems with the car so it never came to him to change that stuff...
Old Mar 27, 2005 | 01:00 PM
Bobo's Avatar
I trust your dad had the air filter and the fuel filter replaced a number of times or the car probably would have been abandoned on the side of the road before or his fuel economy would have suffered so badly he would have looked into it.
It strikes me that all the fluids should be checked and replaced if necessary: eg. power steering, transmission, radiator, clutch (if it has one).
Tire condition? Brake condition? Condition of hoses/belts? That vehicle needs some TLC. You could eat off the engine of my 95SE, but yours should be condemned, lol!
Old Mar 27, 2005 | 01:02 PM
mrgreek's Avatar
the air filter maybe, the fuel filter he definetely hasnt changed and im guessing thats why it sometimes doesnt start on a blue moon...fluids have been checked...brake and tires have been taken care of, hoses and belts no...
hey, i also got 620 km on a full tank of gas...im guessing thats why my dad never looked into the fuel filter...
but that first pic i posted definetely is the fuel filter right? is it a job that a noob like me can do according to the sticky posted about it?
(u guys know the part number for it so i cand find it at canadian tire)
Old Mar 27, 2005 | 01:13 PM
MaDMvD's Avatar
Yes, that drum-like object in that absurdly disgusting Maxima is the fuel filter. You'll need to remove the fuse that controls the fuel pump, fuse 32 (blue 15 amp fuse), and start the car until it stalls about 10 times or so. The reason for this is so that all (most) of the pressure from the fuel lines is released, otherwise you'll NEVER take the top/bottom hose off the filter. Oh, BTW - get a 1996 300ZX filter. Because of the greater surface area, it will last a few thousand miles more than a Maxima filter, and it's about the same price (~$12). Good luck!
Old Mar 27, 2005 | 01:20 PM
mrgreek's Avatar
thnx a lot man, solid...does the 300zx filter work the same was as the maxima? (like do i install it the same way and **** again? thnx
Old Mar 27, 2005 | 01:48 PM
MaDMvD's Avatar
Yes, it's exactly the same thing, except it's a little wider. The hoses fit right in.
Old Mar 27, 2005 | 02:24 PM
99maxk2's Avatar
... that is horrible... please clean it
Would Autozone sell the 1996 300zx fuel filter for 12 bucks? Cause I am not sure if mine has been changed.. and im only gettin 250ish miles to a tank, so ima go but a new filter.
Old Mar 27, 2005 | 02:41 PM
MaDMvD's Avatar
I bought mine at NAPA, which has slightly higher prices, so I'm sure it'll be the same/slightly lower. As for replacing the fuel filter, it will not enhance your MPG. If you want better gas mileage, try buying a K&N air filter, cleaning your throttle body, IAC valve, oil change, new spark plugs, etc.
Old Mar 27, 2005 | 02:45 PM
Bobo's Avatar
Mr. Greek:
I'm somewhat confused (story of my life, lol). Does the car have 255,000 miles on it or 255,000 kilometres on it. Wondering because you refer to 255km which is kilometres as far as I'm concerned, but its a New York vehicle. I still don't believe that the fuel filter has never been changed. Has the vehicle never been serviced at a stealership since day 1, even during the warranty period?
Old Mar 27, 2005 | 03:57 PM
mrgreek's Avatar
its 255 km on it and im from toronto, i dont know why my thing says new york...my bro set up my account once... its been to the dealership back in the day during warranty and they never brought it up to us
Old Mar 27, 2005 | 04:00 PM
wait, 255 km, like 125 miles? or 125,000 miles?
Old Mar 27, 2005 | 04:24 PM
mrgreek's Avatar
my bad...255,000 kilometers
Old Mar 27, 2005 | 05:21 PM
cpt's Avatar
cpt
I just did mine, remove the gas cap in the rear because the tank is pressurized and even removing the fuse and running it till it dies it will still have pressure in the tank and run out the bottom hose. Another thing, I fiddled around with the bottom scew and cut my hands to pieces on the airbox. Then I removed the two clamps between the TB and air cleaner (a 3 minute job) and got right to the screw. Also makes putting on the new one much easier.
Old Mar 27, 2005 | 05:25 PM
Bobo's Avatar
So you have more like 158,500 miles on the car. Didn't your dad keep the maintenance records for the car?
And 375 - 390 mostly highway miles on a tank of gas is nothing to write home about. I have had as high as 550 on the highway and routinely can get over 500 on straight highway driving if I don't drive it like I stole it.
Old Mar 27, 2005 | 06:09 PM
good lord, 500? That's impressive.
Old Mar 27, 2005 | 07:01 PM
mrgreek's Avatar
he has kept the records, but lost them...lol..my 390 miles does make me feel good cause i havent had any real maitnence done to it...but ya...im looking to improve that **** big time...
Old Apr 15, 2005 | 05:24 PM
kingrukus's Avatar
no more maxima...
that is the dirtiest VQ I have ever seen
Old Apr 15, 2005 | 07:04 PM
97maximaman's Avatar
has anyone here tried those fuel injector cleaners. The little bottles u pour into your fuel tank. Do they do anything?
Old Apr 15, 2005 | 07:24 PM
TriniRicanPapi's Avatar
on cold mornings when i start my car the rpms sometimes goes up then goes back down to zero and shuts off. someone told me it might be the fuel injectors. might this be correct and if so how do i clean them?
Old Apr 15, 2005 | 07:33 PM
Neem's Avatar
yeah, after an oil change, I usually and s.t.p. fuel injector cleaner to my 96 GXE (74,000) miles. and I've noticed that my ingine is smoother and more powerful afterwords! Just remember, fuel injector cleaner should be added after oil changes!
Old Apr 15, 2005 | 08:15 PM
DragonMaxima's Avatar
Pulled from the FAQ's-
2) Fuel filter. The fuel filter is small gray cylinder on the back of the firewall that is to be changed on a 60k service interval. It is often to blame for bad gas mileage, but can be a pain in the butt to change, but it can be done. The filter is relatively cheap from Nissan. Some members reccomend buying a fuel filter for a Nissan 300ZX. Its the same size hoses, but twice the size, so it lasts 2x longer and is doubly effective. The choice is up to you. The writeup to change the filter can be found here: www.maximadriver.com
Old Apr 15, 2005 | 08:56 PM
2 Da Max's Avatar
is that bird shiet on the airbox?
Old Apr 15, 2005 | 09:20 PM
Bobo's Avatar
I call BS to adding the fuel injector cleaner after an oil change. I have recently read that using Chevron Techron fuel additive can affect the viscosity of the oil and should be used just before a scheduled oil change.
Old Apr 16, 2005 | 01:21 AM
Dan's Avatar
Dan
No Longer Owns a Maxima
Looks like snow to me...
Old Apr 16, 2005 | 08:01 AM
mrgreek's Avatar
ya it is snow...if u guys are curious in knowing...i am approaching to clean that in the coming weeks...check out the detailing section for a new post im going to start soon...
Old Apr 16, 2005 | 08:52 AM
Bobo's Avatar
I'm waiting patiently for your new post in the detailing section, but I can't wait all day, mrgeek, lol!
Old Apr 16, 2005 | 04:39 PM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
def. post a pic of your engine bay when its all clean
MaxLvr21
Oct 17, 2015 12:11 PM
BobTX10
Oct 7, 2015 08:43 AM
maxima297
Sep 30, 2015 03:32 PM
