Engine Oxidation
Old Mar 29, 2005 | 10:09 AM
CleanMAX98's Avatar
Engine Oxidation
I wanted to Clean up my Engine, and i noticed all the Steel is OXIDIZED!
How/Is there a way i can remove this ugly mess, and what do I need to do for it to me done??
Is there a rubbing compound of any sort?
Old Mar 29, 2005 | 12:20 PM
kc10fish's Avatar
get some scotch bright (green or white) at home depo and start scrubbing .....good luck
Old Mar 29, 2005 | 12:37 PM
SiCkBLaCKMaX99's Avatar
i dont believe scotch bright will really do anythingput CLR on it
Old Mar 29, 2005 | 12:39 PM
renatonetmail
CLR ? more info please...
Old Mar 29, 2005 | 12:47 PM
NmexMAX's Avatar
dot dot dot ...
Calcium Lime & Rust.
It reverses the mineralization process, so instead of corroding, it cleans.
Pics would be nice to see if it's actually reducing or oxidizing.
Old Mar 29, 2005 | 04:14 PM
CleanMAX98's Avatar
ill post pics probably on thursday thanks guys
Old Mar 30, 2005 | 04:09 PM
CleanMAX98's Avatar
I talked to my mechanic and he said CLR is not a good idea because it is flammable, he said the best bet is to brush it with steal
Is the anything else I could do, don't really feel like brushing it
Old Mar 30, 2005 | 04:57 PM
Crockpot's Avatar
cover elec. connections, hose it down, spray simple green in one area and then take a course brush wheel brush and go to town. Make sure to rinse off simple green before it drys or it will stain. Use some armor all on the rubber hoses. yadda yadda yadda
Old Mar 30, 2005 | 05:00 PM
2 Da Max's Avatar
o shiet i didnt know the simple green stains??
Old Mar 30, 2005 | 05:06 PM
Crockpot's Avatar
I guess, haven't experienced it myself.. saw it on a thread a bit ago. Probably just leaves something like water marks like on a non-dried hood.
Old Mar 31, 2005 | 10:12 AM
CleanMAX98's Avatar
cool guys thanks a lot
Old Mar 31, 2005 | 12:50 PM
im telling you clr is you just have to hose your hood down once your done and scrub it all out then hose down again you will never see a cleaner engine bay or you could just chrome all the mettalic parts under the hood like tony arrafio did nice shyt
Old Mar 31, 2005 | 01:00 PM
Jeff92se's Avatar
I'm needing a caw
According to the msds, the flammibility is only "1". As is slight. But it IS corrosive.
http://householdproducts.nlm.nih.gov...ds&id=10006003
Which CLR are you referring to?
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
