Need some help/advice now
I have a 96 maxima WITHOUT the Bose stereo in it. I'm trying to take out the factory radio and intstall a Kenood CD player in its place. The only thing holding me back is that I cannot unscrew the 4 phillips screws holding the factory radio to the side brackets. I have taken off everything else secured to the brackets with the same exact screws (climate controls, old cd player under the radio, and storage box). I even tried using a professional power screwdriver to take them out but even when I put all my weight on top of it, it just starts to strip the screw head. What am I doing wrong?!?
i had the same prob when i was installing my indash screen but i had the bose i ended up dremeling out the screws cause i didnt need them but i really dont know have you tried some pb blaster?? if your not planing on going back stock then i would soak that bish in pb blaster and see if it helps
Those are some very stubborn screws I went thru same thing you are going thru.
The way I was able to get it out was putting a star point screw driver inthere a good size to match the screw and press in very hard and turning very little repedatively to try and break it free, after about 5 times of doing that I managed to break them free.
but if you cant break them free you may need to drill them out, I have extra screws if you need them I could ship then to you no charge if it comes to that.
Yeah man I had the same problem but it was only one screw which is even more frustrating. What I ended up doing is twisting the whole bracket around and the screw turned enough so that i could unscrew it. Goodluck.
