speedometer accuracy
Old Mar 30, 2005 | 10:28 AM
Dan's Avatar
Dan
No Longer Owns a Maxima
How accurate is the speedometer with stock rims? (15" sawblade) I have a GPS which tells you your speed and when the car speedo says 80, the GPS says I am only going 74. Has anyone else experienced this?
Old Mar 30, 2005 | 10:31 AM
Bobo's Avatar
I would take the speedos word for it. I have a 95SE (5-speed) and I believe its bang on. Have you changed wheels and tires? If so, that might have something to do with it.
Old Mar 30, 2005 | 10:34 AM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
That's acutally good, makes you go 5 mile slower, so you won't get pulled over if you going 60 mile.
GPS might have a Delay that's why you see that.
Old Mar 30, 2005 | 10:35 AM
NmexMAX's Avatar
dot dot dot ...
It doesn't matter the size of the wheel, as long as you match it up with a tire of similar diameter,... what's your tire size?
Old Mar 30, 2005 | 10:37 AM
Loe max's Avatar
Speedo is off and for reference, so is the tach
Old Mar 30, 2005 | 10:38 AM
Bobo's Avatar
Didn't notice you still have the sawblades on. OEM tires for that wheel are 215-60-15.
Have you gone to a slightly wider tire?
Old Mar 30, 2005 | 10:40 AM
NmexMAX's Avatar
dot dot dot ...
Even worse in the 5.5g's
Old Mar 30, 2005 | 10:41 AM
Dan's Avatar
Dan
I've got Bridgestone Potenza RE950 215/60-15
Old Mar 30, 2005 | 10:48 AM
NmexMAX's Avatar
dot dot dot ...
[QUOTE=sbddude] How accurate is the speedometer with stock rims? (15" sawblade) Not dead on
Not, I don't have a GPS, and I've accepted that all readings on the stock 4g and 5g Maxima dash aren't very accurate.
Old Mar 30, 2005 | 10:57 AM
PTownMax's Avatar
I still miss the max
speedo accuracy decreases with increases in MPH. On the car and driver page for 95 (the max was car of the year) it said at 70 the speedo could be off as much as 5mph
yadda yadda
Old Mar 30, 2005 | 11:00 AM
NmexMAX's Avatar
dot dot dot ...
Inversely proportional.
mzmtg's Avatar
Minister of Silly Walks
http://www.caranddriver.com/article....&page_number=1
Read and learn.
Old Mar 30, 2005 | 11:36 AM
Dan's Avatar
Dan
yadda yadda
Do you have the link to that C&D article?
Old Mar 30, 2005 | 11:38 AM
mzmtg's Avatar
Old Mar 30, 2005 | 01:20 PM
IWishIHadADub's Avatar
Captain oblivious strikes again.
Old Mar 30, 2005 | 01:26 PM
Skiptronic's Avatar
But where is Captain Obvious?!
Old Mar 30, 2005 | 02:09 PM
NmexMAX's Avatar
dot dot dot ...
Ant96GLE might know.
Old Mar 30, 2005 | 03:22 PM
99se5spd's Avatar
unless the gps is wired to your cars speed sensor dont trust it at all.
Old Mar 30, 2005 | 03:27 PM
Dan's Avatar
Dan
The GPS determines speed based on satelite tracking only. It is a handheld unit. My observation was done at a constant speed with cruise on so refresh rate is not an issue. The GPS self-reports accuracy to be 10-15 ft. It also is consistent with those signs that tell you how fast you are going.
Old Mar 30, 2005 | 03:39 PM
NmexMAX's Avatar
dot dot dot ...
Damn man, you should spend that time, energy, and money on something a little bit more useful.
Old Mar 30, 2005 | 03:42 PM
pavelsmax's Avatar
heres your sign
i doubt the gps is that accurate... i'm a civil engineering student and i work for a civil engineer and our gps equipment that costs well over 50,000 dollars is far from acurate...so i doubt i would trust your gps speed over your speedo with stock tires on there
Old Mar 30, 2005 | 03:47 PM
my99maxisnice's Avatar
maybe your company just sucks at making GPS equipment?
Old Mar 30, 2005 | 04:04 PM
CleanMAX98's Avatar
hahahahahaha...................................... .................ha
Old Mar 30, 2005 | 04:10 PM
NmexMAX's Avatar
dot dot dot ...
Old Mar 30, 2005 | 04:35 PM
pavelsmax's Avatar
we dont make gps equipment .... gps is off when used for surveying by an avg of 3m.... all of the equipment it is only coming of age so i doubt his handheld gps is that accurate
Old Mar 31, 2005 | 08:15 PM
FormorAccordMan's Avatar
There is a speed checker (best way to describe it) on the belt parkway and when I pass it- it is dead on with my speedo
Old Mar 31, 2005 | 09:04 PM
TheFink's Avatar
I have found in the past that the best way to check your speed is when you get pulled over. Just ask the cop how fast he clocked you and see if it matches up.
Old Mar 31, 2005 | 09:08 PM
Their radar guns need calibration too.
Old Mar 31, 2005 | 09:37 PM
AceO's Avatar
Mine is about 4 kph faster on the speedo than on Garmin eTrex GPS, but that one is not too precise...if somebody has a WAAS-enabled GPS those should be quite accurate.
Old Mar 31, 2005 | 09:46 PM
4 kph? That's like .0001 mph!
Old Mar 31, 2005 | 10:11 PM
SpeedyMaxima's Avatar
I did when i put 2001 max rims 6 spoke 17"inch,but i got my stock 16" back
Old Mar 31, 2005 | 11:33 PM
Dan's Avatar
Dan
By the way, I was asking for the link to the car and driver article about the max being car of the year, not the one about speedometers. I am not oblivious.
Old Apr 1, 2005 | 04:23 AM
dgeesaman's Avatar
Maintenance Monster
Take a stopwatch. Go on the highway on an uncrowded day, and look for the mile marker signs. Time one mile going an exact speed on your speedo, do this three times. Go back home and sec/mile into miles/hour. If you have any skills, you should find you get a very accurate number.
Tire inflation pressure, exact tire size, and built-in speedo error all can affect what your speedo says, and IMO it's worth knowing exactly how it reads.
Old Apr 1, 2005 | 05:11 AM
mzmtg's Avatar
You can safely assume that any handheld GPS receiver is far, far more accurate than your car's speedometer. WAAS doesnt matter in this case.
MR2 T'd
Jul 9, 2021 05:06 AM
jchronis2552
Sep 21, 2015 05:52 AM
Djsmaxima
Sep 14, 2015 11:58 PM
humaras
Dec 12, 2000 08:16 AM
