everytime i start my car i smell a thick aroma of gas.is it leaky injectors?
Old Apr 2, 2005 | 06:48 PM
2 Da Max's Avatar
my dad says its a leaky injector wtf? what do i have to do? get techron to clean it out?
Old Apr 2, 2005 | 07:27 PM
lilaclucymaxima's Avatar
Team Ramrod
well... if its a leaky injector that would mean its leaking into your engine right? that means you would have to do a little more than clean it out. you would have to replace the injector(s) theres a possibility that more than one could be bad. then flush out your system. i had all mine replaced a few months ago. if that is the problem, do a compression test or have a mechanic do it to make sure your engines alright
Old Apr 2, 2005 | 07:40 PM
2 Da Max's Avatar
did you feel a difference in performance? how bad is this for my engine? so basically im losing power then? wait... or could it be my leaky rear valve cover?
Old Apr 2, 2005 | 07:41 PM
PAREDLINE's Avatar
Go easy on the taco bell.
Look at your fuel injectors with a flashlight. If one of them look wet then you know what needs to be changed.
It can also be a vacuum leak or a clogged vapor canister.
Can be a lot of things. You just need to poke around.
I have seen an injector leak from the seal on the fuel rail and cause a fuel smell inside the car
Old Apr 2, 2005 | 07:53 PM
2 Da Max's Avatar
i dont see no fluids around the injectors its dry as hell
Old Apr 2, 2005 | 08:08 PM
gtr_rider's Avatar
192.168.1.1
When i had that problem, it was only with a full tank.. ended up the breather hose for the fuel tank sprung a leak
Old Apr 2, 2005 | 08:14 PM
2 Da Max's Avatar
lol i had this car for over a year and never had a full tank of gas in the car so i guess it cant be that :Confused:
Old Apr 2, 2005 | 08:56 PM
BigLou93SE's Avatar
Maybe something simple, like a fuel filter? I don't know, I'm just throwing something out there...
Old Apr 2, 2005 | 10:01 PM
urmab's Avatar
I got the exact same problem well I guess I got to take work on that issue, hmm It shouldint be a fuel filter, well an injector might be an issue , also cloged vac hoses.
Old Apr 3, 2005 | 08:16 AM
2 Da Max's Avatar
na, i just changed the fuel filter back 5k miles ago. clogged vac hoses could cause this? hhm maybe egr?
Old Apr 3, 2005 | 10:09 PM
maxgtr2000's Avatar
KH3 by popular demand
Hole in fuel filter hose, you only smell it when starting up because of the initial increase in pressure at start up? It's worth a glance.
Old Apr 4, 2005 | 11:16 AM
ArcticW's Avatar
That's probably what I got on my car,too. Ive wondered, does the gas smell come through the climate control as well?I haven't checked the fuel injectors: not much I can do about it anyways, with injectors costing $350 a pop . My question is is there any long-term damage? I know it is not healthy to have a busted engine part for any length or time,but the cash simply isn't there right now. Will I have a ruined engine 2 months from now, or will I just have to ...ahem...drive slowly and prudently until I can pay up to the stealership?Thanks
Old Apr 4, 2005 | 11:17 AM
2 Da Max's Avatar
well maybe when i changed the fuel filter a while back its been causing it then?
Old Apr 4, 2005 | 12:33 PM
LeX's Avatar
LeX
Nissan by Nature
EGR causes a 'weird' smell, won't smell like fuel so i doubt it would be that.
Old Apr 4, 2005 | 06:42 PM
4GenMaxMan's Avatar
I had this problem and also my friends 300z had same prob. fuel was leaking out of the rubber hose on the fuel rail. I just loosened up the clamp moved it a little and retightened it. The leak was hard to find because it was only about one drop and it evaporates fast. It doesnt take much to create a powerfull smell.
kjlouis
Nov 24, 2018 06:09 AM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
MikesChevelle
Aug 9, 2015 11:50 AM
mrgooch
Aug 9, 2015 11:00 AM
