Car trouble
Old Apr 5, 2005 | 04:13 PM
Pimpmobile's Avatar
Car trouble
Today I tried to change out my knock sensor using the "cut your hands to lunchmeat" method. Unfortunately that didn’t work so great. I was forced to take off the intake and get down and dirty. After finding those two bolts on the back of the plenhum things went smoothly, KS in and reading 550ohms perrrfect. Got everything back together, all bolts tightened, all connectors plugged in and all hoses where their supposed to be. I start it and .... aww ****.
It will turn over and fire up for about 7 seconds. It tires to idle really really lumpy and then after about 10 seconds the rpms drop and it stalls. I;ve tried reving it a bit to keep it from stalling but the rpms will still drop and stall out. I heard a few pings while I had my girlfriend start it while I was under the hood.
The ECU is through NO codes at all, just 0505 :\
If anyone has any ideas what it could be please help
Old Apr 5, 2005 | 04:32 PM
ewuzh's Avatar
Recheck all your hose connections and make sure they are all on real tight. It sounds like it could be vacumn leak somewhere
Old Apr 5, 2005 | 06:36 PM
ultralighter's Avatar
Sounds like massive vacuum leak. Make sure your plenum connection to intake is good. Its easy to hang up on the 2 rear brace supports.
Old Apr 5, 2005 | 06:44 PM
Ant96GLE's Avatar
Yea thats definately a vacuum leak...
Old Apr 6, 2005 | 03:50 AM
Pimpmobile's Avatar
thanks guys, im heading out there at dawn and will redo the plenum and make sure everything is all tight.
Old Apr 6, 2005 | 04:57 AM
Pimpmobile's Avatar
ok, all better now. The lower RPMs are much nicer now.
turns out when I was putting everything back together the first time I only hand tightened the EGR guide tube bolts. (smack head) see what happens when men try to multitask
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
Slamrod
Apr 10, 2016 05:24 PM
Balkins
Aug 12, 2015 06:39 AM
laparka66
Aug 6, 2015 09:36 AM
