Auto transmission: Shift based on RPMs or speed?
Old Apr 6, 2005 | 06:58 PM
THT's Avatar
THT
Throbbing member
I need to know if the automatic transmission in 4th gens shifts gears based on speed or RPMs. Who knows?
~THT
Old Apr 6, 2005 | 07:01 PM
sunten1
good question...i would think rpms....
Old Apr 6, 2005 | 07:04 PM
THT's Avatar
THT
Throbbing member
I remember reading it's speed-based. But, I don't know for sure.
~THT
Old Apr 6, 2005 | 07:23 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
i would think its throttle ammount. i mean, it will shift up when you let off the gas, wether it be at 3k rpm or 6k rpm, same thing with what ever speed you are at.
Old Apr 6, 2005 | 07:28 PM
A32Matt's Avatar
i'm almost postive it's throttle controlled. i'm not sure if it goes through the TPS or not.
Old Apr 6, 2005 | 07:29 PM
G4nismo's Avatar
damn automatics
Old Apr 6, 2005 | 07:31 PM
2 Da Max's Avatar
i notice when im crusing it shifts from 2500 -3k rpm, but when i floor it it shifts around 6k
Nismo3112's Avatar
Custom User Title
I think its a combination of speed and throttle percentage. @ any % less than WOT, it shifts according to throttle %, because on my sister's car, for example, it will shift from lets say 2nd to 3rd put decreasing the throttle a tad bid. At WOT, it SHOULD always shift at redline, as gear ratios cannot be changed.
Old Apr 6, 2005 | 07:34 PM
BigLou93SE's Avatar
I don't know, but I think that throttle has more to do with it. At full, the auto will search for the lowest gear possible, and drop it there.
If it was speed based, wouldn't you shift at the same speed, no matter what throttle? We know that's not true...
If it was rpm based, wouldn't it shift at the same engine speed, no matter the throttle %? We know this too is not true.
Something to think about, or maybe I'm barking up the wrong tree...jus' throwing out some ideas.
Old Apr 6, 2005 | 07:37 PM
Nismo3112's Avatar
Custom User Title
It's only RPM based at WOT.
Ty, thinkin of a 5spd swap?:grin:
Old Apr 6, 2005 | 07:39 PM
THT's Avatar
THT
Throbbing member
lol, wanna come down and help me? I'll buy you all the Wendy's you'll ever want.
Old Apr 6, 2005 | 07:40 PM
Vlasic's Avatar
you know they found a human finger in a bowl of chilli at wendy's right?
Nismo3112's Avatar
Custom User Title
lol. I was paid with Wendy's food today as well..
Old Apr 6, 2005 | 08:03 PM
IWishIHadADub's Avatar
In my mom's minivan when I floor it the car downshifts. It's throttle based among other factors.
Old Apr 6, 2005 | 08:07 PM
Poowill's Avatar
I coudn't tell you exactly which one it is for sure, but i know speeds detirmine whether it will downshift or not. For example, in order for my dad's 5th gen to downshift into 1st geat @ WOT, it has to be below 30 mph, or it will not downshift. I would believe in that case it would be speed based because no matter if i were in OD or 3rd gear, it would downshift.
Old Apr 6, 2005 | 08:12 PM
Xugg's Avatar
~THT
Trick question, its both speed and rpm sensitive lol
Old Apr 6, 2005 | 08:36 PM
Dave B's Avatar
Not DAVEB the parts guy
On older cars like the sub 2002 Maximas, it based off of rpms, throttle postion sensors, and an engine vacuum. When you floor it or give the car a little throttle, the engine vacuum changes (increases or goes to zero at WOT). The transmission TCM recognizes this and drops to the appropiate gear. On newer cars, the throttle-by-wire system is also involved.
In older cars without lockup torque converters, it was all vacuum based. Same with ignition.
Old Apr 6, 2005 | 08:39 PM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by Xugg
rpm sensitive
and throttle position
Dave
Old Apr 6, 2005 | 10:12 PM
pjp900's Avatar
im almost positive that the max tranny is vaccum controled, the less vaccum there is on the intake manifold the more open the throttle is, not positive though.
Old Apr 7, 2005 | 08:16 AM
THT's Avatar
THT
Throbbing member
Okay, thanks guys. The reason why I asked this question was because before I put installed the 00 VI, my car would redline every gear. Now, she shifts at 6K and I wanted to know why.
~THT
Old Apr 7, 2005 | 08:22 AM
tavarish's Avatar
fwd gone rwd cr00
all i know is under moderate acceleration, it ALWAYS goes ito 4th at 39mph.
Old Apr 7, 2005 | 08:36 AM
Caracicatriz's Avatar
What was that?
~THT
Did you feel a really good increase on your butt dyno with the VI. I'm considering doing this mod in the future.
Old Apr 7, 2005 | 08:47 AM
NmexMAX's Avatar
dot dot dot ...
Screw the butt dyno this has been proven time and time again on a real dyno to gain back all the lost midrange hp/tq the MEVI lost.
Old Apr 7, 2005 | 09:07 AM
Nismo3112's Avatar
Custom User Title
We didn't hook up the RPM Switch yet, but compared to my old MEVI, the midrange on the 00VI would kick the MEVI's midrange's @$$
captchaos
Mar 15, 2016 12:18 PM
bryants95max
Oct 2, 2015 12:52 PM
jcvgn
Sep 10, 2015 08:03 PM
slowlifer
Sep 8, 2015 05:53 AM
jfl330
Sep 4, 2015 01:44 PM
