replacing front struts..
Old Apr 7, 2005 | 02:57 PM
Roman-dude's Avatar
My left front is wobbly and does not really hold the road anymore and it looks like it's time to get the new struts.. (rears were replaced a few months back).
here are the questions
1 should I just get the strut assembly
or also the mounts ?
2 anything else? also, I don't intend on keeping the car for a while.. so any was thinking of going with something cheap....
thanks
btw, what did you pay for the labor to have these installed?
thx
Old Apr 7, 2005 | 03:04 PM
BlackCat's Avatar
RIP '98 Maxima SE
They're quite easy to install. You just need to borrow some spring compressors from Pep Boys, etc. and download the instructions from the link in the FAQ section. Once that's done you have to get a place to do an alignment job.
Old Apr 7, 2005 | 03:17 PM
ThisMaxIsTight's Avatar
if u want cheap....you could go to pepboys and get monroe struts installed...I think they have a lifetime warranty...so if they ever went bad you could just go back and get them replaced for free...also go in the stickys and read about struts...theres a lot of info in there
Old Apr 9, 2005 | 12:44 PM
Nireez's Avatar
Never go with dropzone struts! They suck. Better off with Monroe.
Old Apr 9, 2005 | 05:37 PM
PAREDLINE's Avatar
you don't need an alignment when you change struts on a maxima. the only thing adjustable is the toe. And as long as you dont remove or loosen the tie rod from the rack you'll be fine.
(the tie rod doesnt need to be touched to change the struts)
Old Apr 10, 2005 | 05:55 AM
dgeesaman's Avatar
Maintenance Monster
If you're changing spring, definitely need a realignment. The play in the holes between the knuckle and strut is not insignificant. If it's the same strut, then matchmarking them works ok.
Dave
Old Apr 10, 2005 | 02:51 PM
aprentice's Avatar
i got quoted for $505 to get front shocks and struts w/ alignment, im holding out for now..
kingw323
20
Oct 21, 2015 08:36 AM
Samedi
Aug 12, 2015 01:54 AM
mls277
Aug 11, 2015 07:18 PM
kirkhilles
Aug 8, 2015 10:53 AM
