Help with cefiros
Old Apr 18, 2005 | 06:31 PM
FloodShark's Avatar
Help with cefiros
Got a set of Cefiro's on the way and I read around and saw everyone saying they need slight modification to fit in the 4th gen maximas, but nothing that actually stated what the modification was.
So, any help on what I'm gonna have to do to fit these bad boys in?
Old Apr 18, 2005 | 06:42 PM
venompwr2's Avatar
well you dont really need instructions, it's kind of how it looks. Take out the stock headlights, and then place the cefiro in the opening. Cut out anything that is preventing the cefiro lights from fitting. HOWEVER DO NOT CUT OUT TOO MUCH!!!!!!! or else you wont have any lights to put it. You need to cut out the support in the middle of the opening, and the ones attached to the fender. Most likely you'll have to drill new holes to bolt in the lights too. I dont have any pics to reference, but it's not that bad to do. Just take you're time so it looks good.
Old Apr 18, 2005 | 07:33 PM
Northern Maxima's Avatar
Here's an awesome writeup with pics! It looks sorta complicated to me but I'm not very mechanically inclined. I'll just bring it in to the shop when I buy mine.
http://www.redlinemax.com/3/CefiroWriteup.htm
Old Apr 18, 2005 | 10:01 PM
A Flood99's Avatar
yep cutting is required, used a dremel.....pm me once you get the lights and get closer to installing them
Old Apr 18, 2005 | 10:08 PM
FloodShark's Avatar
Will do, thanks
Old Apr 18, 2005 | 10:10 PM
nadir_s's Avatar
vicodin ... gift of life
eek... "slight" modification? you gotta cut the car apart! lol
have fun
Old Apr 19, 2005 | 02:50 PM
killerVQ30DE's Avatar
Has someone got a pic of the Cefiro lights out of the car? and in?
Old Apr 19, 2005 | 03:17 PM
GoalieKeg's Avatar
I've installed these bad boys twice now, it's sort of an art at this point. The second install was with H4 shields and Phillips 85126 D2R bulbs and Denso Ballasts. And don't worry, that corner light is history.
Old Apr 19, 2005 | 03:28 PM
Kevlo911's Avatar
Kevlo for President
Your car looks amazing,
Old Apr 19, 2005 | 05:36 PM
MrDicks95SE's Avatar
Offset Is Everything.
i had fun cutting up my car. its mostly a cut and fit type thingy. have fun dremeling but dont cut your hand off.
you know about the slight fitment problem right? cuz dont be surprised if they dont fit 100%. none of these will fit exactly like stock except if you bondo the gap or something.
Old Apr 19, 2005 | 06:15 PM
FloodShark's Avatar
Now I'm all worried I'm gonna screw up the cutting and no lights will fit...oof
Old Apr 19, 2005 | 06:18 PM
nadir_s's Avatar
my friend taking his turn cutting up my inner fender:
the biggest peice of metal that was sliced away (bar between corner/head lamps):
Old Apr 19, 2005 | 06:19 PM
just follow the write up and youll be fine. i was skeptical at first but after doing 2 installs its a really simple install if you have a dremel.
the dremel is your best friend. its been mine ever since i got it. got a problem? cut it off.
Old Apr 19, 2005 | 08:01 PM
CHEERS!! ..
Old Apr 19, 2005 | 08:04 PM
G4nismo's Avatar
who sells the blacked out ones? i think redline only has the clear ones.
hey floodshark, how much did u pay for urs? redline is going for $275 which isn't that bad but i want to pay the least amount, despite there cefiros and 1 piece.
is there or was there ever a group deal on these?
Old Apr 19, 2005 | 08:41 PM
MrRogerStatus's Avatar
VQ Disciple
wow you guys actually used dremels lol, I just cut the 2 small tabs on the fender with my small metal cutter, looks like a sissor. And the middle metal piece i just unscrewed the top and pop out the top using a flat head screwdriver.
Pics:
Night Pics
Old Apr 19, 2005 | 08:44 PM
VQ Disciple
sorry for the huge pics
Old Apr 19, 2005 | 09:11 PM
nadir_s's Avatar
check the group deal forum .. they go for about 200 bucks now
Old Apr 24, 2005 | 06:24 AM
VQ Disciple
193 shipped for mine.
check out: http://forums.nycmaximas.org/showthread.php?t=1792
not sure if it's still going on.
Old Apr 24, 2005 | 07:27 AM
hollaatchaboi's Avatar
how do you hold up the grille when you have cefiro's?
Old Apr 24, 2005 | 07:49 AM
If you don't go for the group deal you can find them at http://www.paradox-systems.com/lighting.html for $270.
Edit: Nevermind, they're out of stock right now...
Old Apr 24, 2005 | 10:45 AM
theres a piece inside the hamburger in the middle that holds it in. some people also use zipties on the ends and attach it around the front support. once the hood is closed, the grille isnt going anywhere.
Old Apr 24, 2005 | 11:43 AM
nadir_s's Avatar
i just double sided tape the bottom of the grill ... the hood holds it in place.
Old Apr 24, 2005 | 12:12 PM
GoalieKeg's Avatar
I found that weatherstripping under the grill then 3m tape on top of that works the best, and allows the best fitment of the grill on the 97-99 bumpers. Don't forget the ziptie.
Old Apr 24, 2005 | 04:35 PM
egxflash's Avatar
Hey MrRogerStatus,
so the big metal bracket you didnt even cut it at all? I want to get the cefiros but the thing discouraging me the most is cutting that big metal bracket.
Old Apr 24, 2005 | 04:37 PM
egxflash's Avatar
GOALIEKEG,
how'd you get the weatherstrip to fit so nicely around the cefiros?
I've seen several pictures of cefiros in maximas and none of them look as clean as yours. Yours almost looks stock.
Old Apr 25, 2005 | 03:36 PM
VQ Disciple
Originally Posted by egxflash
Hey MrRogerStatus,
No sir i did not cut mine, i losed the top screw then to a flat head screw driver and pop the top (i did not have panel popers) and i bend it downards. So right now its resting nicely under the light.
I also took the liberty of attaching my grill to the lights and using zipties.
And i agree GOALIEKEG did an excellent job with the weather stripping. Thats why i did not put any on mine yet cause i want to do a neat job like that.
Old Apr 25, 2005 | 03:40 PM
GoalieKeg's Avatar
GOALIEKEG,
Time and patience. I line the entire headlight surrounding first with heavy weatherstripping, and then line the corner with about 3 layers so there's no gap. I eye it then cut it all to fit. If I don't like it, I redo it. I'm having problems right now with the current weatherstripping because my car was recently in an accident (fixed now), but the fender just isn't right. This is only happening on the passenger side.
RinconI30
Jun 11, 2016 08:25 PM
RinconI30
Nov 10, 2015 10:55 PM
black96se
Sep 7, 2001 07:27 PM
SYCEFIRO
May 25, 2001 08:00 AM
99DustMagnet
Jan 1, 2001 04:55 PM
