HELP HELP with programming Remote
Old Apr 20, 2005 | 11:47 AM
Makavelidadon's Avatar
I just received my keyless entry remote i bought from an org member, and im having problems programming it. After i insert the key in 6 times before 10 seconds, the hazard lights blink, but nothing happens after that. Someone please help me.....
Old Apr 20, 2005 | 11:49 AM
MDeezy's Avatar
after the hazard blink your keep the key in and turn to the ON position (dont start)
then press the lock button on the keyless remote, Hazards should flash again, take out keep and open door, programming done.
Close the door and test it out.
Old Apr 20, 2005 | 11:57 AM
do i turn it to ACC or ON?
Old Apr 20, 2005 | 12:10 PM
bump ..
Old Apr 20, 2005 | 12:11 PM
MDeezy's Avatar
cant remember I believe its ON, but if that doenst work then its ACC.
Old Apr 20, 2005 | 12:13 PM
MDeezy's Avatar
Its the ACC
Old Apr 20, 2005 | 12:14 PM
its still not working!!..........how do i know if the remote i bought at least works? because after the first flash, after i press Lock button,(which is the big button), it doesnt flash................. I do have a keyless entry for sure right b/c the hazard lights came on right??
Old Apr 20, 2005 | 12:32 PM
bump bump bump
Old Apr 20, 2005 | 12:34 PM
MDeezy's Avatar
its the ACC you turn too. that should work. did you try it yet?
Old Apr 20, 2005 | 12:35 PM
yes, nothing happened, im thinking its the batteries!
Old Apr 20, 2005 | 12:37 PM
MDeezy's Avatar
this is how to program.
http://forums.maxima.org/showpost.ph...5&postcount=39
if that doesnt work and your followed the instructions properly then is must be the battery. (Battery should be a buck or two at radio shack).
Old Apr 20, 2005 | 12:38 PM
KILLAHDANKS's Avatar
if u look in the how to's of the 4th Gens it show you how its really easy. Its key sequence and holding down lock on the remote.
Old Apr 20, 2005 | 01:46 PM
so i hold down LOCK? not just pressing it once?
Old Apr 20, 2005 | 02:06 PM
MDeezy's Avatar
I only pressed it once, but try pressing it once hard and see if that works if not then try holding it for a second or two. You really should be able to just press it.
if your following the directions correctly and still not getting a responce my bet is your battery is dead. Cause everything is working up to the point when you push the remote button.
Old Apr 20, 2005 | 06:06 PM
is it possible that the remote is dead? I bought it from davey...from the org.
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
maxinout93
Oct 16, 2015 02:53 AM
ToTheMax305
Sep 23, 2015 09:11 PM
flu2000
Sep 14, 2015 12:34 PM
intimidator
Sep 5, 2015 07:23 PM
