Why do my springs make noises?
Old Apr 21, 2005 | 06:13 AM
Zipp028's Avatar
I have had my H&R springs (stock shocks) on for quiet some time now and I have had noises in my suspension ever since. It bothers me to hear the noise it is like it is cheap or something. I thought that after a month or so the noise would go away because the springs needed to be broken in. but i guess not. Does anyone know how to fix this problem? I have heard of wraping the springs but i dont think that will prevent the noise.
Old Apr 21, 2005 | 07:24 AM
2 Da Max's Avatar
well h+rs shouldnt make squeaking noises because the coils dont touch when bottoming out. maybe the spring isnt rested properly on the strut? the spring is probably digging the bottom of the strut area where the spring rests
Old Apr 21, 2005 | 07:58 AM
BlackCat's Avatar
RIP '98 Maxima SE
I had the same problem with my Eibachs on the right rear corner. I had some clunking noise that would come and go. When I swapped them out for the CMS springs I bought some wrap from the electrical dept of Home Depot before putting them on. It works wonders because it prevents some of the coils from rubbing against each other. In the pic below you can see how close the upper coils of the Eibach on the right were when compressed by the color of the dirt.
Old Apr 21, 2005 | 01:04 PM
dr-rjp's Avatar
Are you sure that it isn't the annoying strut mount problem that many members on here (including myself) are having?
Did you ever replace your mounts and/or bearings?
Old Apr 21, 2005 | 01:40 PM
BlackCat's Avatar
RIP '98 Maxima SE
I've replaced the strut tower bearings as well but kept the mounts. It finally got rid of my clunking noise in the front right corner whenever I made a left turn.
Old Apr 21, 2005 | 02:01 PM
njmaxseltd's Avatar
Springs tend to make noise if there not seated (installed) correctly.
The top spring perch on the front of your car is clocked, meaning it only goes on correctly in one direction. I find quite a few DIY suspension jobs that are not assembled correctly up front. The word OUT on the upper perch is supposed to face outwards or be in line with the lower strut mounting flange. I can't tell you how many times I find that part not lined up correctly which causes the spring to sit unevenly and of course make noise. Another thing to watch for is the upper coil must sit very evenly into the rubber grommet.
Old Apr 21, 2005 | 05:22 PM
Zipp028's Avatar
I have never replaced my mounts. I wasnt sure if that would cause me to have the noise. Its weird because I have the "creeking" noise in the back and i have the "clunk" noise in the front (drivers side i suppose)
So what you are saying is that my springs may not be sitting correct? And or i may need to replace my mounts?
Old Apr 21, 2005 | 05:34 PM
ManualMaxima's Avatar
5th Gen till she dies!
i second that, improperly seated spring
Old Apr 21, 2005 | 05:35 PM
The Russian's Avatar
your struts are blown bro sorry 2 tell ya
Old Apr 21, 2005 | 06:31 PM
Zipp028's Avatar
my struts will make noises like that? i thought it would just bounce a lot if my struts were blown? they cant be blown because they are making the same noises as they did when i put them on..
Old Apr 21, 2005 | 07:54 PM
well i had struts, and when i went over a bump, i haerd them, went to mechanic, and they said my struts wer blown, soo i ono
BkGreen97
Apr 2, 2016 05:47 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
jfl330
Sep 4, 2015 01:44 PM
Justin Kroll
Sep 2, 2015 11:06 AM
