Pulled ECU Code 0505...
Old Apr 24, 2005 | 09:20 AM
AxisKill's Avatar
The check engine light was on .. so i pulled the code... :
0505 ...
which comes out to "No Failure Recorded/Detected"
.. mkay, so i said to myself, wtf is the point of that even being a code if there is no failure recorded or detected?..
So i went along and reset the ECU (to turn off check engine light). It went off, and stayed off for about 5 minutes, only to come back on again.
I pulled ECU codes again, and again got 0505. Frustrated, i reset ECU once more. And again, the check engine light came back on approximately 5 minutes later.
... So now i come to you guys, any ideas what the problem may be?
Old Apr 24, 2005 | 09:34 AM
Loe max's Avatar
Instead of resetting the ECU (clockwise/counterclockwise, repeat again) try that step just one time. I think your ECU is still left in self-diagnosis mode.
Old Apr 24, 2005 | 09:42 AM
AxisKill's Avatar
thanks for reply. let me give it a try.
Old Apr 24, 2005 | 09:55 AM
AxisKill's Avatar
mmm ... didn't reset ECU, but instead pulled some real codes.
0503 - problem with the front Oxygen Sensor on the right cylinder bank
0304 - Knock Sensor
... i was planning on changing up the KS as is, been getting weird MPG lately.. meh.
now i have a project ahead.
Anyone know any places where i can get o2 and KS for cheap in north east? (NJ ?) ... Pepboys?
-thanks ..
Old Apr 24, 2005 | 09:59 AM
Loe max's Avatar
0304 - Knock Sensor
-thanks ..
My suggestion would be to replace the KS first. My 0303 code (Front Oxygen sensor left bank) cleared itself when I changed my KS, as strange as that may sound.
If you must replace the O2 sensor, my suggest would be a Universal 3 wire sensor. The difference between a universal and an OEM replacement is that the OEM connects right to the harness where as the universal one requires you to cut and splice wires (directions are provided, but its straight foward and the supplies are in the box)
Old Apr 24, 2005 | 10:02 AM
AxisKill's Avatar
werd, sounds good.. i guess i'll go shopping for KS first... what are the exact benefits of Universal 3 wire sensor over OEM O2?
Old Apr 24, 2005 | 10:23 AM
Loe max's Avatar
Its about $20-$30 cheaper
If you have open-end wrenches, it'll work fine for removal of the 02 sensor. IIRC its about 22mm. The KS bolt is 12mm.
Old Apr 24, 2005 | 11:25 AM
AxisKill's Avatar
K. Thanks :-).. most places around here (Bergen county) are closed on sunday.. but im going to go do up my KS first chance i get, and then see if i still have an O2 problem...
Old Apr 24, 2005 | 01:58 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
if youve never replaced the KS yet, you should replace that first. but if you have in the past, you should replace the o2 sensor first. in fact just pull out the ks, and if it is cracked replace it, and then reset your computer. drive for a week and then if the CEL comes on, replace the defective part.
Old Apr 24, 2005 | 04:23 PM
AxisKill's Avatar
i don't believe that the KS has been replaced before, unless nissan does it at 60k or 100k check or w/e the f*ck it's at. I just got the car last week with check engine light already on (about 113k miles).
I wanted to make a post on some other topics about perhaps doing a GD on a KS, because it's always up on the boards somewhere, i see it's @ around 89$ right now and theres a good 2-3 other topics open with interested buyers. (Yes 89$ isn't much, but being cheap is the way to be!)
I was wondering, maybe i can just go to the junkyard, take out 2-3 KS from 95-99 max's and swap them into my car?
I mean shieeeet if they're defective my ECU should let me know right?
Old Apr 24, 2005 | 04:44 PM
Loe max's Avatar
As long as the KS tested out fine from the Junkyard (multi-meter). Otherwise, its risky because you don't know how old that KS ect...
I'm just wondering if some KS's were over torqued from the factory? When I put mine on, I only torqued it a quarter of a turn to tighten it down firmly but still easily to remove.
gustavison
Oct 4, 2015 06:50 PM
220k+ A32
Sep 22, 2015 03:08 PM
QueensMAX
Sep 15, 2015 04:14 AM
