STEREO WIRE PROBLEM
Old Oct 9, 2000 | 12:38 PM
PM240SX
I HAVE A PROBLEM. I RECENTLY STRIPPED MY STEREO FROM MY OLD 89 240SX AND WANT TO PUT IT INTO MY 97SE. I HAVE A AMP WIRING KIT. I 'M TRING TO HOOK UP MY MAIN POWER CABLE TO THE BATTERY BUT I DON'T A EASY WAY TO WIRE THRU THE FIREWALL. HAS ANYONE HAD THIS PROBLEM BEFORE AND IS THERE A EASY TO GET THE WIRE TO THE TRUNK.
STEREO UPGRADE PIONEER HEADUNIT, INFINTIY KAPPA 6.5 COMPONENTS WITH 6.5 KAPPA REAR DECK. SONY 50X4 AMP
2 10" MTX WITH 360 KICKER AMP.
Old Oct 9, 2000 | 12:42 PM
Bernie Lomax's Avatar
Passenger side
On the pass side of the firewall there is a large rubber plug that you can poke through using a nail set or an exacto knife... It appears behind the glove box. Good luck.
Old Oct 10, 2000 | 05:31 AM
breaux124's Avatar
If you can't find an existing hole that you can stick the wire through, there should be spots in the firewall that are thinner metal that can be punched out for a hole. Also, make sure that you put a rubber gromet in the hole, this will protect the wire from fraying over time and causing a short or a fire. I didn't do this and eventually I had to replace some things, so spend the 30 cents for a rubber grommet.
The Frye
Sep 2, 2021 11:03 AM
Maxie40
Sep 14, 2015 11:28 AM
Violator
Sep 9, 2015 10:14 AM
