D2 coilover owners, noise?
Old Apr 25, 2005 | 08:37 PM
Mr.Duck's Avatar
hey guys, i was talking to a guy who owns a 5th gen and has a clicking noise, do the D2's for the 4th gen have these noises? or are you guys getting any weird noises?
Old Apr 25, 2005 | 09:28 PM
Larrio's Avatar
The Definitive AE Master
it won't be completely silent in all conditions and situations no matter what you do. Unless we start spending $3000+ for superb coilovers like porsches and such
Old Apr 25, 2005 | 09:34 PM
JeEvE's Avatar
I had clicking noises in the front and thought they would never go away. Jumbo here on the org told me to tighten the two allen bolts that prevents the piece (part that bolts to knuckle) from rotating. After I did that, the clicking completely went away. Now, the coilovers make no noises at all. The clicking can be from many different things so im not saying its just because of the allen bolts.
Old Apr 25, 2005 | 09:39 PM
Zack342's Avatar
other than that how do you like the ride quality and so forth? i am in need of suspension upgrade and i would love to do coilovers but fear the noises.
Old Apr 25, 2005 | 10:05 PM
Mr.Duck's Avatar
i am leaning more towards the Ksports at the moment, so i think i may go with those since they are almost the same design
Old Apr 26, 2005 | 12:04 PM
Dementia's Avatar
I posted about this in the group buy thread, but I'll paste it here...
Originally Posted by ImmaSquashYou
i had clicking noises on my front coilovers too. i finally figured it out since i didn't have it before but then i did now. its because the bottom mount on the front's have the two allen screws that tighten the coilover from moving. if its' clicking, its cause you've tighten it too much. yes, thats right, too much. you HAVE to make sure that the load is distrubuted evenly, very hard to do. also spray some wd-40 on it, it will also help. but try not to screw it in too much, and that should fix your problem.
Originally Posted by Dementia
Well thats not where my clicking was coming from... and I cannot understand how tightening those allen screws to much would be a bad thing. If those screws aren't tight enough and the coilover turns in the lower mount, your ride height will change.
My clicking noise was coming from the pillow mounts. When steering... the coilover was pivoting on the lower spring perch, not on the pillow ball like it is supposed to. When the torque became to much and the spring couldn't pivot anymore, then the pillow ball would suddenly move , causing the noise. The pillow ***** were lubricated and now they move properly. This sounds much like the previously known problem with the pillow ***** that was supposed to have been corrected.
Here is my personal word of advice to those who haven't yet installed these. Nobody else has mentioned this, so I'm assuming everyone else noticed, but I'll say it anyway. On the lower mounting for the coilover that connects with the 2 large bolts to the hub... be sure to notice that the upper bolt hole on the coilover is slotted. You have to set the hub fully to one side or the other of the slot and then torque the **** out of that bolt or it WILL move. This is what was causing my funky camber issue, not what I previously posted about.
I've been thinking about this... about those allen head bolts. If I had to guess... I'd say that by loosening those bolts you've made that lower mount the point of least resistance and that your whole strut is pivoting on the threads inside the mount instead of the pillow ball. This would explain why the noise stopped, because it would no longer be forcing the pillow ball to move. I can imagine that if it is pivoting in the lower mount, it will strip the threads in short order.
My recommendation to you would be to tighten them back up, unlock the steering wheel and have someone steer it back and forth from lock to lock. Watch the tops of the coilovers while you're doing this. If the top of the coilover (adjustment **** and indicator) is not turning in relation to the wheel but then moves suddenly and makes the popping, this the cause of the noise.
Just my guess though.
Old Apr 27, 2005 | 11:26 AM
1MAX2NV's Avatar
A few days after initial installation, you should retighten everything. The spring perch and the two large nuts especially.
Old Apr 27, 2005 | 02:28 PM
Jumbo™'s Avatar
My Maxima thinks your Maxima is HOT!
The only weird noises you'll hear from my car are screams of joy! I love 'em, you'll love 'em. Buy them, install with a couple friends over beers on a Sunday afternoon, get an alignment and truly enjoy 'driving' your Maxima.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Need help
23
Oct 2, 2015 08:56 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
