Bad KS => failed emmissions??
Old Apr 26, 2005 | 07:36 PM
sanekb7's Avatar
Does anybody know if I would be able to pass emmissions expection with bad knock sensor??
Old Apr 26, 2005 | 08:07 PM
bigtimber's Avatar
I don't see why not as long as you don't have a CEL
Old Apr 26, 2005 | 08:09 PM
1996blackmax's Avatar
Not here in California, I do not know about PA. A bad KS will not trigger the CEL, but it will show up when they connect the OBDII to it.
A while back my car kept failing the inspection. It was not due to emissions(those passed), but rather because the OBDII monitors kept saying not ready. I could have passed with 2 not being ready, but I had 3. I took about a month and a half for the other one to kick in.
Old Apr 26, 2005 | 09:25 PM
maximazation's Avatar
doesnt california have the best emission laws? lol
Old Apr 27, 2005 | 04:34 AM
njmaxseltd's Avatar
If PA does emissions inspections using the OBDII port, you'll fail.
Even though your CEL isn't on, the test looks for stored trouble codes. If you have any, you automatically fail inspection. I just had my car inspected here in NJ the other day. I'm looking at the print out they gave me and the box under the emissions test looks for other trouble codes present and next to it a box for the codes that are discovered.
You might want to get the KS changed before you have your car inspected.
Old Apr 27, 2005 | 07:13 AM
RichMax's Avatar
Boosted like Snipes tax refund
or, you could always rig up a bypass and reset your ECU (possibly the better option if your car is CA-emissions spec). I got quoted a few hundred bucks to replace my ks since the upper intake manifold had to be removed to replace the damned ks...
Old Apr 27, 2005 | 07:12 PM
If they plug into your OBDII port, DO NOT reset the ECU right before the test. This will only have all of your OBDII monitors say that they are not ready, and you will fail due to this. Just change out your KS sensor. You do not need to take off the intake plenum to replace it.
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
