Jerky ride throughout powerband
Old Apr 30, 2005 | 10:22 PM
Fekz's Avatar
Went out for my first run in my maxima today. seemed to be running decent at low speeds, but any attempt to give a little punch resulted in the car "misfiring". As I drove on, the slight jerk became violent at low speeds to the point where I had to coast in neutral until this improved. This happened more frequently at lower speeds after continued driving (1st and 2nd) and became less violent at higher (40 - 60) speeds. It's a 5-speed if that helps any.
Coil packs
Maf sensor
bad/leaky injectors
o2 or knock sensor
Im thinking its one (or more) of these. Any ideas?
Old Apr 30, 2005 | 10:26 PM
5alive's Avatar
Do unto others...
Coil packs
Maf sensor
bad/leaky injectors
o2 or knock sensor
How long since you've driven it? How much gas was in it when you parked her?
Old Apr 30, 2005 | 10:30 PM
Fekz's Avatar
This is the first time i've REALLY driven it since purchasing. Has about 6 gallons of gas left.
Old Apr 30, 2005 | 10:35 PM
CreativeDesignz's Avatar
seems like me and you are having the same problem
Old Apr 30, 2005 | 10:39 PM
Fekz's Avatar
Did yours jerk to the point where it almost became unsafe to drive?
Old Apr 30, 2005 | 10:48 PM
yea it was like hitting a brick wall...or like hitting fuel cut
Old Apr 30, 2005 | 10:55 PM
5alive's Avatar
Do unto others...
When did you get it?
Old Apr 30, 2005 | 10:57 PM
this morning around 10 am...it was raining here in jersey and my cai filter was wet and i think that may have something to do with it but it stopped after i disconnected the cold air extention. so then 5 hours later i go out to the car and it starts actin all messed up again but then stopped after 5 minutes.
Old Apr 30, 2005 | 10:59 PM
5alive's Avatar
Do unto others...
You probably have water in your gas.
Old Apr 30, 2005 | 11:01 PM
5alive's Avatar
Do unto others...
And YOU, probably have water in your air.
how would we just all of a sudden get water in our gas and air? if i had water in my intake i would think it would evaporate after 5 hours and from driving. it stopped jerking after i disconnected that pipe...drove for 1/2 hour with no problems, then just got in my car to drive my gf home and it did it again for 5 minutes then stopped.
Old May 1, 2005 | 06:37 AM
njmaxseltd's Avatar
Two words....
COIL PACKS
Old May 1, 2005 | 08:13 AM
well went out this morning to advance auto parts...car drove fine. i must have sucked in some water or something because the problem dissapeared. I changes my spark plugs they needed a changing anyways and then ran soem seafoam through that sucker. shes purrin like a kitten now
Old May 1, 2005 | 10:23 AM
vqssl2914's Avatar
I get a jerk too between 1st and 2nd... (auto 1997 gle)
Old May 1, 2005 | 07:18 PM
maximizd97's Avatar
Originally Posted by njmaxseltd
Two words....
COIL PACKS
Agreed. Coil Packs.
Old May 2, 2005 | 09:48 PM
Fekz's Avatar
Originally Posted by maximizd97
Agreed. Coil Packs.
Is it recommended you by coil packs new? or can I settle for used?
Old May 3, 2005 | 09:11 AM
Fekz's Avatar
anyone have any idea?
Old May 3, 2005 | 10:34 AM
nearthisbridge's Avatar
I'd only buy used if you knew the history of them, like how long they were driven on. Around here the junkyards charge you like $50 a pop for a used one (if you can even find one with a 4 gen, hah), when for $30 more I can go to the dealer and get one that hasn't been driven 60k miles already.
Old May 3, 2005 | 11:26 AM
l3ftonm3's Avatar
ask around you can get them in the forsale section on here for pretty cheap. I just got 3 for a real good price.
D Mason
Jun 21, 2016 04:43 AM
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
