Flaps underneth the front bumper
Old May 3, 2005 | 07:32 PM
white97gxe's Avatar
So i was changing my oil this weekend and i was looking for the filter. I unscrewed the 2 flaps directly under the bumper and most of the screws are rusted so they broke. Yeah i know i should have checked the forums first since its not even located over the flaps. So now the flaps are loose and anytime the wind picks up i hear a clapping noise. Do i need these flaps or can i just take them off ?
Old May 3, 2005 | 07:33 PM
rome06's Avatar
flaps??? are u talking about ur splash guards??
Old May 3, 2005 | 07:34 PM
nadir_s's Avatar
vicodin ... gift of life
sounds like it ....
Old May 3, 2005 | 07:38 PM
ti2tmax's Avatar
Has his VINs memorized
yes I belive he is. They prevent water and dirt from getting into important things, such as your belts and pulleys, so they are rather important.
Old May 3, 2005 | 10:14 PM
motocross416's Avatar
The splash gaurds in both my dad's and my max are removed. The ones that go over the tires are still there but not the ones that are right behind the front bumper. I haven't noticed any negative effects to this. Sometimes if I hit a big puddle, I will get steam from under the hood from water getting in there, but its no big deal. My bolts were all rusted too and were breaking off, so I took out the splash gaurds. I haven't had any problem with water getting on the pulleys or causing any damage in the engine bay, so I'd say go ahead and pull them off.
Old May 3, 2005 | 10:17 PM
Jepht20's Avatar
Custom User Title...
i need to pick up a new one...mine is bent out of shape from the previous owner, looks like it was bent somehow the wrong way so it hangs down and looks ugly.
i'd keep them on there to prevent water and junk from going up excessively. my friends car stalls out everytime there are decent puddles in the road and i bet it wouldn't if he had these on his car.
Old May 4, 2005 | 05:10 AM
renatonetmail
While taking one of the screws off from the driver side the one that also holds the wheel well one, the screw broke and half of it stayed inside. how do i get that out?
Old May 4, 2005 | 05:52 AM
white97gxe's Avatar
Yes! that is exactly what happend to me, except it was alot more then 1 screw.
Old May 4, 2005 | 06:34 AM
renatonetmail
did you figure out how to get it out?
Old May 4, 2005 | 06:39 AM
ti2tmax's Avatar
Screw remover, or drill it and tap a new hole.
edit: drilling and tapping won't work on those will it...
Old May 4, 2005 | 06:50 AM
BLaKtOut's Avatar
i believe he is talkinga bout the plastic pieces under the car the ones u can remove to get access to ur foglights and oil change not the mudflaps
Old May 4, 2005 | 07:06 AM
wildmaxi's Avatar
undercar flaps
if any of you want to get rid of your flaps...I need them...email me at
salehts@yahoo.com
Old May 4, 2005 | 07:17 AM
renatonetmail
i don't know if there is a screw remover so think... this srew is a philliphs-10mm head and it holds both the end of wheel well flap and a foglight flad together to the car....
Old May 4, 2005 | 07:42 AM
BLaKtOut's Avatar
yes thats the flap im talking about they atually sell a kit that drills ahole into the screw then u unscrew it and it takes the nail it worked for a concrete nail i think it can take off a 10 mm nut but ya those tend to get rusted the most
very fast because they are located udner the car
to answer your question yes you do need them especially if you have an intake but if not you still do there alot of wires very close and the oil filter is right there not something you wanan risk especially on the NewYork streets
Old May 4, 2005 | 07:44 AM
renatonetmail
where do they sell that kit? any name, brand, picture?
Old May 4, 2005 | 08:26 AM
96mAx2fast's Avatar
where can we get that under car flap, protecting crap.. whatever its called.. Anywhere besides the stealership?
Old May 4, 2005 | 08:30 AM
renatonetmail
peek a boo:
http://www.mytoolstore.com/hanson/hanson.html
http://www.toolprice.com/category/screwextractors/
"These bits have a 135 degree split point which makes it a self starting drill bit.....blah blah blah"
Old May 4, 2005 | 08:43 AM
BLaKtOut's Avatar
ya somethign like that i was talking about and the pieces i believe only the stealership would carry them or a junkyard if your lucky
Old May 4, 2005 | 09:14 PM
FormorAccordMan's Avatar
I have noticed tghat all 4th gen max's have that "bent" look closest to the pasanger side- I thought mine was busted too when I got mine- But I then noticed the same exact thing on every other max. I think the engine sheilds are just precut that way.
Old May 5, 2005 | 08:37 AM
BLaKtOut's Avatar
i had that to but ifixed it up took the screw it fixed it look too look straight now no more bent ithought it was messed up thats y i ended up putting it all straight
The Frye
Sep 2, 2021 11:03 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
Maxima30
Sep 7, 2015 06:13 PM
