car is missing
car is misfiring
ok I noticed that if you ease in it to redline it dosent miss but at wide open throtle it misses horibly I am thinking that is it one of my coils what do you guys think BTW:the car has a rather new set of spark plugs and 210k
thanks Brandon
thanks Brandon
Originally Posted by DragonMaxima
Your title of your message is very mis-leading.
Sounds like your car was stolen.
coilpacks?
misfiring during accel
Hello, New to this forum and sorry for asking for info already. I have a 96 Maxima (VG??) which will misfire during moderate to heavy accel. Otherwise the engine runs fine and smooth. I see a reply on this thread talking about a possible bad coil. Is there anyway to try and isolate between the 6 or is this a trial and error thing. Info below on problem.
-1996 Maxima auto, 180k miles
-Codes revealed bad knock sensor. Replaced sensor, cleared codes,
codes remain clear at this time 0505. Missfiring still exists.
-Took a look at the TPS with an analog meter. Needle sweep seemed
smooth with no jumping during throttle range of movement. WOT and idle
readings were normal.
-Engine runs smooth at light throttle applications and cruise. Highway
mileage is 27-29. Considered normal.
-Plug are Bosh platnium's with about 40k on them. Inspected, all looked
good.
Any help would be greatly appreciated. Honestly I bought this car for a work car 2 years ago for next to nothing. I have grown to really like this car and plan to find a low mileage SE 5spd once the better half gets out of nursing school. Thank you in advance for you help.
good.
Well, I almost don't believe it. I did not think that a spark plug change would ever fix this problem. I just couldn't be that lucky. Son-of-a-B if it didn't completely correct the missfire under load. Put in NGK G-powers and all is good. Take the plugs and add the fact that the knock sensor was bad for who knows how long and the car feels like I did some bolt on HP mods. Thank you for the info.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
what a joke, supposed to give you twice the sparh hence more power, what junk they were.
