where are the back 2 intake manifold bolts?????please help
Old May 5, 2005 | 10:14 AM
97maxxx's Avatar
i am taking it all off right now to change my valve cover gaskets and i cant find the back 2 bolts-everything else is fine i just cant find the back2 -can someone please tell me exactly where they are? please -thanks so much
Old May 5, 2005 | 10:37 AM
Nealoc187's Avatar
SLOW
They are... on the back. Just put your hand back there and start feeling around for them. They are spaced about 4-6" apart I'd say, they are bolted through two metal braces coming up from the block, and you also have to remove the EGR bolts to get the IM off if that's what you're trying to do.
Old May 5, 2005 | 10:55 AM
Dubbya's Avatar
VK56 Inside
I would say that they are about hand length down from the top of the IM too. Just squeeze your hand back there.
Old May 5, 2005 | 12:16 PM
Kevlo911's Avatar
Kevlo for President
They are on brackets, I believe they are 14mm
Old May 5, 2005 | 12:31 PM
Pimpmobile's Avatar
PITA to get off especially if you got beast hands
Old May 5, 2005 | 12:39 PM
deezo's Avatar
Just take your time when trying to get them of because it's hard to get to them. Also be aware of the 2 coolant hoses and 2 EGR tube bolts you will need to disconnect to pull the manifold off.
Old May 5, 2005 | 02:17 PM
nismology's Avatar
It is possible to remove the IM manifold out of the way without disconnecting the 2 coolant hoses in the back.
Old May 5, 2005 | 02:30 PM
97maxxx's Avatar
i just finished up the project but now its rough-it like goes from 1k-1.5 and just juumps around a lil bit ???????? any idea -i checked everything over again -i dunno what it could be -maybe intake or something?
Old May 5, 2005 | 02:41 PM
Dubbya's Avatar
VK56 Inside
Check to make sure all your coils are plugged in. Double check all the hoses around the throttle body. I know I missed a few connections when I put mine back together. Did you hook the MAF back up? Is there a CEL?
Matt93SE
May 24, 2019 02:58 PM
vingodine
45
May 21, 2016 12:46 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaxStock
Aug 12, 2015 08:33 AM
Maxboy23
Aug 11, 2015 11:59 AM
