97 Timing Chain/Connecting Rod Issues
Hello All,
A buddy of mine that I work with has a major problem with his Maxima... it makes a loud knocking sound when idling and driving. He took it to a Nissan dealer that is near work.. I have taken my max there in the past and completely trust them.... they are real good folks. They called him a little while ago and said that it seems to be his timing chain... it needs replacement. On top of that, his connecting rod is going south and they suggested that the engine be replaced as well. Sounds like parts and labor is going to run him about $2000.00 (for timing chain only)... not good, so I was going to ask for suggestions from you good people.
1. Have you all heard of this kind of problem on the Max before? Is it common?
2. Would you recommend he have the engine rebuilt, or replaced?
3. If he has it replaced, can you suggest a place that would have an engine? Maybe he should go with the dealer for that?
I suggested a blown Chevy like they convert on the older Z's, but that may not be practical.
Thanks in advance for your help... I appreciate it and I know he will!
Wade
![chuckle](https://maxima.org/forums/images/smilies/chuckle.gif)
Wade
www.car-part.com - get a new engine and have it put in...first go to another independent mechanic and have the problems re-diagnosed.
Originally Posted by nismology
How the hell did somebody determine that a connecting rod is on the way out?? WTF??
![lamer](https://maxima.org/forums/images/smilies/lamer.gif)
![Slap](https://maxima.org/forums/images/smilies/slap.gif)
Originally Posted by Stephen Max
Rod bearings make a very distinctive knocking sound when the clearance gets excessive. Whether or not the mechanic is BSing is another matter.
A competent mechanic would've been more specific than to say the whole connecting rod was bad. That in itself would cause me to look for another opinion for sure. And these engines are toleranced so tightly that i doubt the rod bearing is the root of his noises. Even if you run the engine with no coolant and no oil, the head gasket is likely to give before anything mechanical does.
I've met a lot of mechanics who were not too particularly articulate. Besides, maybe the mechanic did indeed say it was a rod bearing and that distinction got lost in the translation along the way to what we read above.
My rod bearings were the first to go when my oil pump died.
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
kingw323
20
10-21-2015 08:36 AM
Finkle
09-27-2015 09:53 PM
