Here's a hint - 99 ECU!
Old May 12, 2005 | 06:05 PM
dcmaxclub's Avatar
dedicated to the nonbeliever, and to those that believed
my friend put it in his car today, and will post more later!
Old May 12, 2005 | 06:21 PM
MDeezy's Avatar
nice. 99 GXE? we need some 99 proof here.
Old May 12, 2005 | 07:07 PM
2 Da Max's Avatar
o shiet rev limiter for the 99ers
Old May 12, 2005 | 08:12 PM
dcmaxclub's Avatar
JWT ECU
extended rev limiter, timing fuel maps etc....
Old May 12, 2005 | 08:20 PM
Ninos_Maxima's Avatar
be the change u want2C
^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ^^^^^^^^^^^^^^^^what?!?!?!?!?!?!?!??!
Old May 12, 2005 | 08:22 PM
Crockpot's Avatar
<-- confused
congrats tho ?
Old May 12, 2005 | 08:29 PM
BlueC's Avatar
wat
No way..........
Old May 12, 2005 | 08:38 PM
dcmaxclub's Avatar
It was the 96 swap from JWT. He'll post all the details tomorrow.
Old May 12, 2005 | 09:21 PM
zazon's Avatar
holy crap.
Old May 12, 2005 | 09:25 PM
maxspeed96CT's Avatar
The original VQ...
awwwww shiiiiettt
i wonder if its 99 or 99.5
Old May 12, 2005 | 09:56 PM
dcmaxclub's Avatar
SE.
My digicam is broken so the only pic I could get was from the cell. Maybe next week we'll be able to get some videos. It felt good though, especially in the upper rpms
Old May 12, 2005 | 09:59 PM
tedo007's Avatar
faster than you think
WORD! whoa dude. need some more proof. im gettin excited
Old May 12, 2005 | 10:08 PM
dcmaxclub's Avatar
trust me.
I've been doing the max.org thing since back in 1998 (any of the real old heads in the dc section would remember me - eben, richard, addae, jaypee, jason etc..), and I wouldn't post some BS. I gotta keep my good name lol.
It's real.
jouvert00 will give all the details tomorrow
Old May 12, 2005 | 10:39 PM
Flava_24/7's Avatar
Boosted Panda
I remember reading in the past that it could be done, just needed to have some rewiring done.
Is that what was done in this case?
Old May 12, 2005 | 10:44 PM
GoalieKeg's Avatar
Can't wait to see what the f he did to the wiring harness.
Old May 12, 2005 | 11:08 PM
dcmaxclub's Avatar
the wiring harness is fine. you have to move one wire to a different pin space, or splice into it and run a new wire to the other pin space.
maxspeed: donno if its a 99 or 99.5.
Old May 12, 2005 | 11:20 PM
1FSTMAX's Avatar
what about imobolizer bs? how was that by passed?
Old May 12, 2005 | 11:38 PM
Dstyle's Avatar
We hope you are prepared to give a lot more info on this!
Old May 12, 2005 | 11:51 PM
Maximus_95's Avatar
but will that even help our performance considering how we lose huge amounts of hp towards high end ?
Old May 13, 2005 | 12:17 AM
dcmaxclub's Avatar
He'll give you more info. I would but:
1.) I don't know ALL of the details on what was done to fix the earlier problems / don't want to give bad info, and
2.) He needs the post counts haha (j/k Jason lol)
But I believe the reason it didn't work the first time did have something to do with the security system.
In addition to their solution to that issue, they wanted to make sure that the new connection to the fuel pump relay (the wire I was talking about switching) was good, so they made the change internally. Therefore, if there was another problem it wouldn't take hours to figure if it was due to the ecu malfunctioning or if jouvert hadn't switched the wire correctly.
So in his case, at this point anyway, it really is plug and play. Beside that I can tell you it felt good driving it
I don't know if the extended redline will help or not. It seems like it did in 1st and 2nd - at 7k shifting from 2-3 gave a nice chirp. I don't know if you would want to go that deep in the higher gears. There probably will have to be some time learning where to shift again for best performance, before it's known for certain. In any case the car feels faster overall, even if you don't take the new limit into account. Guess time will tell.
Old May 13, 2005 | 01:51 AM
SPiG's Avatar
SomePsychoGuy
Shifting that high without some kind of VIM(MEVI or -k) will not help you. But it is very nice to know you have the option.
Old May 13, 2005 | 03:54 AM
ti2tmax's Avatar
Has his VINs memorized
Ooh, I'm excited too! What about engine balancing at that higher RPM, I mean it's not much, but it is @1000 higher right? oh, maybe it's only like 600 huh?
Old May 13, 2005 | 06:52 AM
Flava_24/7's Avatar
Boosted Panda
So JWT made these changes to the ECU?
Which means they will be offering a program for the 99 maximas?
Also, without a VI, theirs no need to go any higher then 6500. Your not building any more more power past that.
Old May 13, 2005 | 07:46 AM
jouvert00's Avatar
Hey guise it's now been confirmed the 99 max is now capable of running a 96 ecu.
For those of you who were following my previous posts,the actual problem that did not allow the 96 ecu to run was the "NATS" cam crank sensor wire needed to be reversed so the car will run also they manually linked pin 117 to pin 11 for the fuel pump control internally.
They also told me the internals may vary on the 99 models depending on production date. Anything more technical contact JWT they will answer any questions you may have.
The car feels much more responsive and stronger in all gears, it honestly feels like adding another y-pipe but with the extended rev limiter, and as DCMAXCLUB mentioned i now get a healthy tire chirp from 2-3rd gear which it never did before.
Overall it was srtessful with the back and forth but definitely worth it in the end.
1)All 99 models can benifit just let jwt know the production date of your vehicle.
2)price is still the same as the standard upgrade.
3)95/96 ecu can be used in the 99 but the 96 is better suited "probably will not throw a CEL".
4)my factory and after market alarm still works.
5)no cel thus far.
Now i can focus on the MEVI.
Old May 13, 2005 | 08:17 AM
meanbean's Avatar
Whoo Hooo...Great news! Thanks for sharing.
Old May 13, 2005 | 08:19 AM
THT's Avatar
THT
Throbbing member
Wow...just another trump card JWT holds over TS.
Old May 13, 2005 | 08:26 AM
DandyMax's Avatar
3.5 in the works
That's certainly some good news for all the poor buggers with 99's (well until now they were). lol.
If only JWT weren't so slow!
Old May 13, 2005 | 08:53 AM
dcmaxclub's Avatar
bah, forget that buy these headers from me... brand new, never used $300
Is your car a 99 or 99.5?
anyhow, here's the other pic off my cell:
Old May 13, 2005 | 09:02 AM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
Sorry I had to make a correction, That is not called CEll, It is called ECU.
Cel= Check Engine Light. i am sure you know that...
Old May 13, 2005 | 09:11 AM
dahman45's Avatar
this is awesome!!!!!
Old May 13, 2005 | 09:14 AM
Flava_24/7's Avatar
Boosted Panda
He said off my CELL
which means from his cell phone.
Old May 13, 2005 | 09:18 AM
Zack342's Avatar
5)no cel thus far.
Congrats man. i just had a couple quick questions.
1) how long did JWT take t o do the ECU?
2) IS your car a Fed spec 99 or a calispec 99
3)was it still needed for you to move the pins on the ECU harness or was it a plug and play and JWT did it all internally to the ECU?
Old May 13, 2005 | 09:21 AM
chenzarino's Avatar
One PLease!
Old May 13, 2005 | 09:24 AM
Maximus_95's Avatar
................uhmm.........
He said off my CeLL (Phone)
Old May 13, 2005 | 09:35 AM
jouvert00's Avatar
1) It took a little over 2wks total
2) my car is a calispec 99, does not matter cali/fed will work.
3) jwt moved the pins internally no harness work involved just plug and play.
Old May 13, 2005 | 09:48 AM
rimrocka0834's Avatar
This is all true guys i just got off the phone wit JWT and they said that now they can do since tehy figured out that all tehy had to do was move the pins. Im excited!!
deezo's Avatar
Congrats to you 99 guys.
Old May 13, 2005 | 09:58 AM
hey jouvert00 u got an AIM cause i got sopme more questions
Old May 13, 2005 | 10:04 AM
massfastmax's Avatar
what gains does this actually give you and why would you want a 96 ecu over a 99
Old May 13, 2005 | 10:15 AM
sterlingmaxima's Avatar
This is what I have to say ****ing right i am soooo excited this was the one thing really that I hated about my car all 99 owners should rejoice
