Where is our distrubutor?
Old May 15, 2005 | 10:21 PM
isawyou's Avatar
Where is the distrubutor in out car? For that matter, where are the spark plug wires? I've never had a car where these things weren't obvious until the Maxima.
Old May 15, 2005 | 10:29 PM
ThisMaxIsTight's Avatar
im not sure where the distrutor is, haynes manual will tell you .... there are no spark plug wires, theres only coil packs that connect to the spark plus
Old May 15, 2005 | 10:34 PM
maxspeed96's Avatar
no distributor on 4th gens.
Old May 15, 2005 | 10:36 PM
idlingmike's Avatar
Distributorless ignition. No mechanical distributor, no cap, no rotor, no wires.......just like just about every single car made in the last 15 years or so
Old May 15, 2005 | 10:42 PM
ChristheNite
yeah hahah this was a fun thread to read...just did the plugs today...3 under the front plastic cover on the engine, and 3 behind where the front strut tower brace would cross...
Old May 16, 2005 | 01:09 AM
Guttermouf5150's Avatar
thats not true at all.
Old May 16, 2005 | 01:19 AM
idlingmike's Avatar
I might have been pushing it with the 15 years part, but what cars in say, the past 10 years or so are still mechanical style distributors?
Old May 16, 2005 | 01:32 AM
well if you are talking mechanical distributors, as in points, then you better push that back to about 30 years. if you mean mechanical as in simply having a cap and rotor, Chevy trucks still had them at least as late as 2000, and Dodge still used them as late as 2003
Old May 16, 2005 | 01:40 AM
maximazation's Avatar
you are very correct, the B series of Honda engines (B16, B18, B20) all used distributors..until the K series came out using distributorless ignitons..ie. coil packs.
Old May 16, 2005 | 01:47 AM
SPiG's Avatar
SomePsychoGuy
It wouldn't surprise me if there are still a few cars that use distributors. I know the Honda B series used distributors and it was made until 2001. The Nissan Xterra and Frontier with the VG30E or VG33E all had distributors until the new 2005 VQ40 came out. I am sure there are still a few cheap domestic cars that if they don't use distributors they just stopped.
I am not saying that distributors are in any way a good thing, but for some vehicles don't really need direct ignition. Distributors need more maintenance but, we all know some of our coils are terribly reliable either.
Old May 16, 2005 | 01:48 AM
SPiG's Avatar
SomePsychoGuy
Beat me to the B series. Oh well.
Old May 16, 2005 | 02:09 AM
hahaha...
also, with the whole distrubutor thing, also kind of brings up why some automobiles still use drum brakes instead of discs and pushrods instead of overhead cams, and other OLD technology..
Old May 16, 2005 | 07:05 AM
nismology's Avatar
Lower manufacturing costs. All about the $$$...
Old May 16, 2005 | 07:09 AM
95jr6708's Avatar
Yeah something like all that...somethings seem to change, while others dont.
Old May 16, 2005 | 07:57 AM
SPiG's Avatar
SomePsychoGuy
I think it is the same reason why some FWD car still don't have a rear independent suspension.
Old May 16, 2005 | 08:02 AM
NmexMAX's Avatar
dot dot dot ...
But had it in 94 then again in 04 ...
Old May 16, 2005 | 08:05 AM
mymaxlvsattn's Avatar
slackass
pushrod tech may be old...but it works well.
-not trying to open up an argument on this thread.
Old May 16, 2005 | 09:15 AM
isawyou's Avatar
Okay, so I've had a couple of cars newer than '95, but they had traditional spark plug wired, etc. Anyway, the reason I'm asking is due to my faulty tachometer (I wrote about this a couple weeks ago, and still haven't figured it out). Most people I've spoken to say it probably has a bad connection at the distrubutor. If my car doesn't have a distributor, from where does the tach get its "information"? I am quite certain the bad connection is not in the instrument cluster itself.
Old May 16, 2005 | 09:16 AM
njmodi's Avatar
Do I get a tax break?
I think someone already told you that your tachometer is bad....or maybe that was someone else...
Old May 16, 2005 | 09:19 AM
MaximaSE96's Avatar
Maxima Owner
i believe its gets connection at computer......but i am prolly wrong
Old May 16, 2005 | 09:27 AM
RichMax's Avatar
Boosted like Snipes tax refund
Don't NASCAR stock cars use carbeurators? Forgive my spelling if it is off.
Old May 16, 2005 | 10:03 AM
NmexMAX's Avatar
dot dot dot ...
What does that have to do with this thread, we're talking about distributor-less ignitione, Nissan DIS.
BTW, Our tachs are "calibrated by 1st graders" (credit SR20DEN) they're badly off, and I also think the 5th gen is more off than the 4th gen, that's been in my expirience.
Old May 16, 2005 | 10:40 AM
tavarish's Avatar
fwd gone rwd cr00
The Honda D-series engines use distrubutors, as well as the B...a few of my friends have them..I don't know about some more recent versions though..
Old May 16, 2005 | 10:47 AM
Loe max's Avatar
www.autozone.com for an online haynes manual.
Old May 16, 2005 | 10:50 AM
Loe max's Avatar
Since we are speaking Honda, the first USDM Honda product to use DIS is the 2000 J30A1 on the Honda Accord and the J32A1 on the 2000 Acura TL. Previous J-series engine used a Distributor. One a side note, Honda uses a air-density vs. our metered air.
Old May 16, 2005 | 12:57 PM
SPiG's Avatar
SomePsychoGuy
My tach seemed a bit off too. I had an RPM switch for my MEVI and it was off and my tach would let me bury it into redline by about 300-400 rpm so I assumed my tach was off. When I asked about it, they said don't worry about it there is nothing you can do.
You can't realiably compare between maxs well because tire size and pressure, speedometer calibration (sometimes even worse than tach), and many other factors can throw this off.
You can try a new guage cluster or a new sensors or even a new ECU, but none fo them promise any results. The most reliable option is to get something with a digital rpm readout. The better ODBII readers have them, many of the piggy backs and car computers add ons will also have them. You could always just mount a huge tach and shift light on your dash.
IIRC the ECU knows how fast the engine is turning by the crank position sensor. The ECU decifers the signal and distributes that to the coil packs and the tach.
Old Jul 26, 2005 | 07:04 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
saw some info on this thread and wanted to correct some info.
the 4th gen does not have a distributor, nor is it DistributorLess Ingition.(if it were DIS, it would be 3 coils), our cars are COP(Coil Over Plug)
Old Jul 26, 2005 | 07:23 PM
TurTLe*'s Avatar
^ yep.. Coil over plugs. Not sure what to make of them but i think i rather have the ould distributor due to the cheaper maintence.
Old Jul 26, 2005 | 07:33 PM
Loe max's Avatar
wtf the answer was received months ago why are you post whoring or echoing?
The ignition system is called NISSAN DIRECT IGNITION SYSTEM (NDIS) for the final time
Old Jul 26, 2005 | 07:34 PM
WielkiWaac's Avatar
MaximaDriver
what a question. we dont have one. simple as that.
Old Jul 26, 2005 | 08:13 PM
killcrap's Avatar
3rd gens are called NDIS as well.
wait, so are 4th gens? and 5th gen? AND 6th gen. WOW your post was useless.
Old Jul 26, 2005 | 08:56 PM
ManualMaxima's Avatar
5th Gen till she dies!
like distrib cap and rotor button, ford focus has it, lancers, alot of cars still use them.......i sale like 50 of them a day
Old Jul 27, 2005 | 10:18 AM
Loe max's Avatar
Your post was equally useless since it was answered months ago
Old Jul 27, 2005 | 02:26 PM
ryant35's Avatar
Yup. They grab a budwiser,marry their sisters, and tune their carbs. Fuel injection is too complex for the south.
Indy, Cart & F1 use high tech fuel injection.
Old Jul 27, 2005 | 02:27 PM
Loe max's Avatar
Nascar rules say carb only don't they?
Old Jul 27, 2005 | 09:31 PM
ryant35's Avatar
Exactly, the rules were written by the same sister marrying, bud drinking hillbillies.
KaneStyles
Mar 14, 2009 09:02 PM
Dementia
Dec 22, 2004 04:08 PM
MDeezy
Mar 1, 2004 08:31 AM
NikaL
Jul 4, 2003 09:48 PM
MrSmith
Jan 21, 2003 11:19 PM
