trunk problem
Old May 17, 2005 | 04:48 PM
gsmith795's Avatar
trunk problem
my trunk opens fine when i use the key but my auto open button next to the driver seat doesnt work. i can hear it making a sound in the rear of the car when i push it but the trunk doesnt open. i already made sure that the little lever was set to unlocked so that it should open when i push the button. ideas?
Old May 17, 2005 | 05:03 PM
jedinyte120's Avatar
i just had this problem.i took off the latch near the bumper and had a metal shop weld an extension piece to it. after they welded and sanded it down smooth,i bent it in a 45 degree angle,so that it will hit the trunk lid latch. mine was worn out thats why i had to do that. good luck,hope this helps.
rog
Old May 17, 2005 | 05:48 PM
Black Maxima
rog
DAAAAAMMMMM STRAIGHT...I brazed an extention piece on the little latch thingy. Now it grabs and works perfectly.
Old May 17, 2005 | 05:55 PM
MaXiMaGiRL's Avatar
well, i have the same problem, mines was the spring. it was loose already, so it needed replacement. but it came up well cuz now that i have a system i can only open it with the key, and if they try to jack my stuff, they wud need the key. lol. i wont be replacing it. it works better for me, but the spring is my problem.
t6378tp
Sep 29, 2018 04:27 PM
mrgooch
Sep 21, 2015 08:43 PM
lux97Max
Sep 14, 2015 07:07 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
rbaker100
Sep 6, 2015 02:46 PM
