Getting the VQ even smoother
Old May 20, 2005 | 06:24 PM
FormorAccordMan's Avatar
Today i was in my friends '01 i30 adn he commented to me on how smooth the engine is. I agreed that it seemed smoother than my '99 max. He told me that his engine ran smoother since he switched from 5-30 to 10-30. He basicaly said it was due to the 10-30 being thicker. I really liked how smooth his car was and was wondering if us with the original DE engine have found that swtiching from 5-30 to 10-30 made the engine feel smoother. I know that the 01'2 have like 30 more horses but it is ofset by extra weight, but his car seemed to feel faster and had a harder pull than mine. any ideas. His car has 80k and mine has 60k
Old May 20, 2005 | 06:32 PM
maximazation's Avatar
i've been using 10W30 ever since i got my car, so i wouldnt know how to define smooth..
Old May 20, 2005 | 06:35 PM
liquidx's Avatar
Sorry to have to post a question here, but I still don't have enough credits to create my own thread.
Does anyone know if it is possible to put an 1156 bulb in the reverse light housing(lights for reverse drive)? I have a few extra 1156 bulbs hanging around, and would LOVE to throw them in there, and give them a MUCH crisper, sharper PURE white light.
I think the stock was a 194 bulb or something. I'll open the light fixture up tomorrow to see if they would even FIT, nevermind have problems with melting or whatever.
I'm especially asking because I am not in reverse for more than 30secs at a time - in terms of heat build up being a problem.
Old May 20, 2005 | 07:17 PM
Spaniard's Avatar
That should not make a difference.... The oils are both 30 wt. when hot so they should both have the same viscosity characteristics... IMO its something else- Like maybe a newer and/or different engine?
Old May 20, 2005 | 07:58 PM
Mishmosh's Avatar
prolly softer motor mounts.
Old May 20, 2005 | 08:04 PM
dayglo's Avatar
yea i bet
i30s are a 'nicer version" of the max's arent they?
Old May 20, 2005 | 11:21 PM
Mishmosh's Avatar
Could also be improvement going from 99.5 to 01. I know my 95SE is a lot less smooth and quiet compared to my dad's 98 GLE. A LOT.
Old May 20, 2005 | 11:26 PM
Loe max's Avatar
Engine mounts are the same part# with automatic transmissioned GLE/SE and I30/I30t
GXE auto/5speed and SE-5speed uses standard mounts vs. electronically controlled engine mounts.
Old May 21, 2005 | 01:34 AM
paultyler_82's Avatar
liquidx, I know you can't post your own threads yet, but it's not nice to hijack, just a heads up... as for your reverse, it uses a 1156 bulb already, your only option really to make it brighter is to use the specialty 50watt 1156 type bulbs, your reverses won't normally be on long enough to make melting the housing or harness a concern at all. Now... no more hijacking, be a good orger and all that bs.
Old May 21, 2005 | 01:57 AM
Maximus_95's Avatar
Originally Posted by dayglo
yea i bet
huhmm.....i wonder if my car is as smooth as an i30. i Have an i30 motor in with everything, except tranny though.
Old May 21, 2005 | 05:03 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
get your crankshaft balanced. then it will be smooth.
Old May 21, 2005 | 05:25 AM
SkinnyMax's Avatar
maxima no more
The different oils would only makes a difference at startup when the engine is cold.
Old May 21, 2005 | 05:27 AM
WielkiWaac's Avatar
MaximaDriver
me too. ive been using 10w30 since i got my max
Old May 21, 2005 | 05:28 AM
JClaw's Avatar
2000-2001 VQs are smoother. Ever seen a dyno curve for 00-01s? FLAT AS HELL. The dyno curve in 95-99s is like a roller coaster. Ups and downs and over before the best part.
Old May 21, 2005 | 07:31 AM
Loe max's Avatar
Well put
Old May 21, 2005 | 08:18 AM
Kevlo911's Avatar
Kevlo for President
Hell I have the 00vi, which makes the dynocurve smoother. And my car is still not as smooth as the 00+. I am sure it is a combination of newer engine/car and better grounds. Maybe a few more things too.
Old May 21, 2005 | 08:23 AM
a HA! Okay- I guess thats why his car had that whiplash torque goin on .
Old May 21, 2005 | 02:32 PM
97SEdriver's Avatar
this place is dead
I use different oils depending on the season. I race auto-x and do the occassional NASA HPDE, I dump 20-50, 10-30, 10-40 synthetic blend oils all in at the same time. The only problem I saw this winter was I put 1 qt of 20-50 and the oil light was coming on at idle, I think that may have been too thick for winter. But where I drive I hit 90-100mph almost every other day, just keeping up with traffic.
Old May 21, 2005 | 02:43 PM
naslime's Avatar
i noticed my engine runs smoother after a recent oil change (10w30) and seafoam through brake booster hose
Finkle
Sep 27, 2015 09:53 PM
Justin95SE
Apr 17, 2001 02:49 AM
