What could be the problem with my max, it wouldn't start...
Well, it was wierd, I just drove the car from Burger King to my house to start working on fixing my friends 300zx, he was having problems with his headunit and alternator whine, we fixed it in a matter of seconds by adjusting the ground. We were just finishing up, and I told him that he would need to get the antenna adaptor to make the two pin antenna harness into a one pin to go into his new head unit. Well, we were on our way to Pep Boys, and instead of putting his car together and drive it, we were taking mine. Here starts the problem.
Keep in mind, I drove the car the entire day, and just needed to drive to PepBoys, and so we got into the car, I step on the clutch and proceed to start the car, but nothing would go. I checked the battery, and the battery is good, so I checked all the fluids, everything was fine. I started to think it could be the starter, and was basically just trying to turn the car on, but nothing worked. After a couple of minutes of trying everything, I gave up and closed the hood. I went to try again, and the car turned on. What exactly could be the problem? Any help, I'm gonna goto my mechanic tomarrow, but having an idea of a possible problem is gonna help me .
Lets say that if it is the clutch safety switch, and it didn't disengage, what should I do to make it work better... I don't know how else to work it, sorry for the crappy English :-p.
And let's say that it might be the ignition switch, where is this located, and what can I do to check it/troubleshoot, and possibly repair the problem?
Any other DIY troubleshooting methods I should try will be beneficial .
Same thing happened to me. I tried starting it over and over -- nothing. Had to push start it every time. I figured it couldn't be the starter, because push starting it should rotate the starter and make it temporarily work. The next day -- no problem. I've been driving it this way for over a week now, no problems. The previous owner replaced the neutral safety switch about a year ago.
P. S. I don't mean to be rude, but your entire first paragraph really isn't relevent to the thread.
As for the camshaft sensor, the real only way to fix this problem, is to replace it? I have no real idea on the component, but would something as simple as cleaning it up, or readjusting it would help me if the car was to do this again? Oh, and where is the camshaft sensor? :-p. Sorry for the newbism, but asking questions helps the learning process .
its the starter, mine had the same thing happen. the little magnets around the coil inside the starter get worn out or the coil inside the solenoid gets shorted. sometimes it would start and sometimes it wouldnt. changed the starter and no more problems.
If the car turns over, it's not the ignition switch.
If you get a click when you turn the key, then it's probably a starter or battery.
If you get nothing, then it's the ignition switch.
I replaced my clutch safety switch only to still have the problem.
You can usually push the key in towards the steering column while in the start position and the car will start. I've been doing that now for almost 2 years.
First post - great forum - very helpful! I have a 2004 but I passed my '96 onto my son and he has same problem. He gets a click but randomly no crank at all. Took it to the garage and had starter motor and relays replaced - expensive. They said starter was pulling three times correct amperage and was "cooking" so replaced it. Problem still exists! Garage said battery is good so seems like ignition switch is the culprit, yes (even though it clicks)? He got it to start after rocking the car in frustration when it failed. The next day it failed to start for me but I got it to start by putting it in neutral. Today it started! Frustrating for a car I put a bunch of money into so it would last longer so he could use it. Anybody have other ideas - confirm it's the ignition or maybe just a loose connection? Thanks for the help.
When my starter went bad, you would hear the electric motor trying to turn, but nothing happens or it is just stuck grinding. Now on very very very few occasions when I go to start my car, nothing happens period. I will just keeping turning the key back and forth and eventually it starts. My problems seems more like a short then anything else. Just my .02.
I agree. If you don't hear the starter activate at all, it is the ignition switch until proven otherwise, especially if startup is normal any other time. If your cranking sounds sickly at times, it could be the battery, ground, or starter. If it cranks normally but keeps on doing so for prolonged periods without firing up, then the crank or cam sensors could be faulty. Personally, I've never heard of anyone's clutch pedal switch going but I guess that is possible, and people with auto's can have their neutral/park switch fail.
trungg86
09-04-2015 04:58 AM
