Breather filters???
Old May 25, 2005 | 06:19 PM
SiCkBLaCKMaX99's Avatar
Breather filters???
Has anyone developed any brether filters for the vq 3.0 because i see a lot of hondas with these and i would much rather have that then the stupid hose we have. anyone have this already or know of this??
Old May 25, 2005 | 06:45 PM
nosispower's Avatar
What's a breather filter for?
Old May 25, 2005 | 06:48 PM
Kevlo911's Avatar
Kevlo for President
The ones at Autozone/Advanced auto don't fit good, the inlet is too small.
Old May 25, 2005 | 06:51 PM
sunten1
Old May 25, 2005 | 09:43 PM
dayglo's Avatar
i asked this question a while ago i think...at a meet , i saw someone with a small filter on the valve cover i think it was. front center of the engine block
aperently it doesnt do anything at all. someone said it was a breather valve for gasses and the hose goes to your intake and gets burned back through your engine..not sure what's true.
but i was thinking....if youre getting used air recirculated back around again from this valve...wouldnt there be some kind of gain from not tainting the clean unburnt air [optimal] in your intake passages? i would guess your mpg would go down but maybe youd get somehting out of more pure air?
i dont know anything!
...if you do it i will too
Old May 25, 2005 | 09:53 PM
cefiro8701's Avatar
A breather filter relieves your engine of positive crankcase pressure and recycled carbon vapors from your engine, which cause loss of throttle response due to build-up on the throttle body. The Breather helps resolve that problem, by venting the vapors into the atmosphere.
and another link on breathers and their pros...
http://www.karlsnet.com/mopar/crankcase.shtml
Old May 25, 2005 | 09:55 PM
cefiro8701's Avatar
first quote is from 2kracing.com
Old May 25, 2005 | 10:51 PM
NmexMAX's Avatar
dot dot dot ...
I used the one from AZ but had to "bore" it our with a knife etc..
Old May 25, 2005 | 10:55 PM
cefiro8701's Avatar
does it really affect warm up??
Old May 25, 2005 | 11:40 PM
egxflash's Avatar
id think if you did get a breather filter like those on hondas, itd just be purely cosmetic. I mean, come on its a short hose that was on there at first for chrissake, how would a filter give any positive gains. They do look better than just a hose there though
Old May 25, 2005 | 11:46 PM
cefiro8701's Avatar
who knows til you've tried....maybe a placebo effect like a tornado or a electricsupercharger...
Old May 26, 2005 | 06:46 AM
NmexMAX's Avatar
dot dot dot ...
No peformance gains you 's Just keeps the intake tract a little cleaner ...
Old May 26, 2005 | 06:58 AM
felix's Avatar
Sittin' On Chrome
do you still have it on? got a pic?
Old May 26, 2005 | 07:24 AM
Magikone69's Avatar
any possibility this keeps the TB clean since spent air isnt being re-circulatecd back in, thats a reward itself IMO
Old May 26, 2005 | 10:07 PM
i just like the way it looks and if it does anything than thats just icing on the cake
Old May 26, 2005 | 10:11 PM
cefiro8701's Avatar
well...wouldnt it help because the warm air coming from the valve cover is now cut off from the intake??i dunno just a thought i had...
Old May 26, 2005 | 10:42 PM
DR-Max's Avatar
This is part of the PCV system and is emissions related kinda like the EGR system. Read this for a more indepth explanation. Yes its for another car but the system is similar to ours. And yes, employing a breather filter will help the engine but might not be good for emissions.
I have seen some org members use this anyway but its been a long while since I've seen those threads. Without the search function, its pretty hard to locate them anymore. I wouldn't worry too much about this breather filter. If you want to try it anyway, go for it.
**Edit**
Just saw this also. Notice it says that its not for use on emission controlled vehicles.
Old May 26, 2005 | 11:06 PM
cefiro8701's Avatar
well....what if you take it off before the smog test...sorry i didnt read the stuff yet...
Old May 26, 2005 | 11:34 PM
DR-Max's Avatar
If you've read the article, you will realize that u will need two breather filters. Read on and find out why.
Old May 26, 2005 | 11:51 PM
cefiro8701's Avatar
yeah i wasnt planning on just using one...
Old May 27, 2005 | 01:29 AM
Fr33way™'s Avatar
Wild for Width
There ya go , sorry for the size . .
Old May 27, 2005 | 02:05 AM
cefiro8701's Avatar
is your hacked airbox upside down??u think it produces any gains??
Old May 27, 2005 | 04:35 AM
Chickan's Avatar
where is the second one located, I only see the one in the picture ...
I also vote mostly cosmetic...
Old May 27, 2005 | 09:51 AM
DR-Max's Avatar
It sucking all that hot air in from the engine??? I highly doubt it, this produces a pretty loud intake growl though.
Old May 27, 2005 | 02:59 PM
cefiro8701's Avatar
i tried the upside down method and noticed that it makes no difference in the sound..
Old May 27, 2005 | 03:09 PM
drivinmax
my03maxima
Jul 28, 2024 07:40 AM
Justin Kroll
Oct 1, 2015 07:03 PM
Redfox
Sep 28, 2015 10:41 AM
bumpypickle
Sep 20, 2015 08:22 AM
