Air Intake Temp Sensor
Old May 27, 2005 | 07:24 AM
drivinmax
What Do You Do With The Air Intake Temp Sensor When You Install An Intake, There Is Nowhere For Me To Reinstall The Sensor, Do You Just Let It Hang There?
Old May 27, 2005 | 07:27 AM
renatonetmail
nope.... if you bought the right intake it should come with a predrilled hole for it....check it out:
http://www.ricotumbao.com/car/cai2.jpg
edit: those 3 holes (bigone and two small) are precisley for it...since i have a 95 its different than 97-99 cuz they use a groummet hole type but in my case is hold by 2 screws.
The scary part is you need to get threadlocker (loctite) <-- expensive and sealant cuz we (95-96) have a little plate (where screws screw into) from inside the intake that engine can ingest it if come loose.
Old May 27, 2005 | 07:36 AM
drivinmax
Ya I See It Mine Doesnt Have That
Old May 27, 2005 | 08:32 AM
maxgtr2000's Avatar
KH3 by popular demand
Word to the wise, put your stock midpipe back on and fabricate another hole somewhere in the intake for the sensor.
Old May 27, 2005 | 08:54 AM
drivinmax
alright i'll try that
Old May 27, 2005 | 09:14 AM
DcMaN's Avatar
i ziptied mine do that little emblem on the fender inside the engine bay its like directly infront of wehre the intake would be i just took my emssions test today and passed
Old May 27, 2005 | 01:38 PM
RA030726's Avatar
I'm nutty for Nissans
put it near the filter and forget about drilling holes.
Old May 27, 2005 | 02:00 PM
Gramdacious's Avatar
tap into the square black plastic resonator box behind the Mass Air Flow sensor. If yo uhave a dremel. This takes literally 2-5 minutes. And the sensor is still monitoring the air going thru the intake.
Old May 29, 2005 | 06:29 AM
scrhale's Avatar
LOL ... I must be the first person to get this to work without the predrilled hole. I had one hole, so obviously it wouldn't fit. No problem for me. I just grinded down the entire sensor down to only the physical part it needs to work and then stuck it down the hole. With the rubber that was meant for the hole, it was a perfect fit and no CEL!!! I'll post a pic if yah want.
Old May 29, 2005 | 06:37 AM
drivinmax
ya post a picture
Old May 29, 2005 | 07:24 PM
Maxima 504's Avatar
When I had my intake on I just put the sensor hanging inside the filter.. I had no problems for over 2 years with that set-up..
Old May 29, 2005 | 10:29 PM
Ninos_Maxima's Avatar
be the change u want2C
I just transisterd mines today, you guys should do It, my car felt stronger
Old May 29, 2005 | 11:15 PM
DAVE Sz's Avatar
Hooooooonda.....
^You're a dumbass. Transistered? The IAT sensor has nothing to do with the way the car runs, absolutely nothing. If your car feels stronger it's all in that little, empty head of yours.
Old May 30, 2005 | 07:12 AM
larryseibel's Avatar
transisterd...is that like a terd that rides the bus? i think its called a resistor and yes it can be used but dont expect any significant gains in h/p.
Old May 30, 2005 | 11:23 AM
DAVE Sz's Avatar
Hooooooonda.....
^Another one. Did you not read what I wrote? The IAT does not control any engine parameters or anything else whatsover. You can take it out completely and it will be the same, you'll get a CEL but it won't hinder peformance.
Old May 30, 2005 | 11:27 AM
drivinmax
ya so dont buy them off ebay for $20
Old May 30, 2005 | 02:36 PM
DR-Max's Avatar
When I had my HAI, I put the IATS inside the cone intake. Of course the wire has to go thru somewhere. All I did was put the cone on the maf adapter with the wire squeezed in between. Don't tighten the clamp too much. I had that for almost 2 years w/o any problems.
Old May 30, 2005 | 02:50 PM
drivinmax
way to be ghetto about it
Old May 30, 2005 | 02:57 PM
DR-Max's Avatar
True but it works. Besides noone can really see it. It's not like having a ghetto Pep Boys tail pipe and actually call yourself classy. But if you want to put more work into it for what its worth....go for it.
Old May 30, 2005 | 03:00 PM
drivinmax
haha you have a pep boys tail pipe
Old May 30, 2005 | 03:23 PM
ManualMaxima's Avatar
5th Gen till she dies!
i just through it in the intake filter.....
Old May 30, 2005 | 06:09 PM
If its there it does something, it reades the air temp going into your block, obviously then it does something to the timing.
I ment to say resistor, sorry. and I got it for free, they only cost like 2 cents at some electronic stores. Why dont you try it before calling people names you dork, gimme my knife back too
Old May 30, 2005 | 06:12 PM
RA030726's Avatar
The way to do it:
95/96:
97-99:
Old May 30, 2005 | 06:19 PM
O dave maybe for the 95/96 its different cause the sensors are different, and they are less restrictive with all the everythings on lower year maximas. but I still want my knife!
Old May 30, 2005 | 07:53 PM
dmBK's Avatar
How 'bout them cliffs?
i had it just like in the pics above in my 96, now i just tucked it in between the filter and the left shock tower. that sensor is only used for certain diagnostics, not while the car is running normally. so do what i did, or zip-tie it to the mid-pipe, makes no difference.
Old May 30, 2005 | 08:29 PM
DAVE Sz's Avatar
Hooooooonda.....
Again, no. It's there to tell the engine the intake air temperature, nothing else. The ECU just reads it and leaves it the **** alone. I know what a resistor is, dork, I've been using them for the last 5 years of my life. Like I said 3 times in this thread, it does nothing, it's pointless. Maybe you want me to copy the FSM page where all this is said? Will that shut you up? If you want your knife go to Wisconsin, it's at the bottom of a lake somewhere probably.
Old May 31, 2005 | 06:02 AM
you wont get a cel if you resitor out the iat sensor. i have had a resistor on mine for 2 yrs! plus, i did read what you wrote thats why i said "DONT expect any significant gains in h/p"
Old May 31, 2005 | 10:45 AM
DAVE Sz's Avatar
Hooooooonda.....
You won't get a CEL if the IAT is just dangling around the engine bay either.
You said significant gains. Meaning there will be some when in reality there won't be. Since that it the case why replace the thermistor with a resistor when it's COMPLETELY pointless?
Old May 31, 2005 | 11:32 AM
felix's Avatar
Sittin' On Chrome
I did after 2 weeks. Just replaced it and it went away.
Old May 31, 2005 | 12:27 PM
DAVE Sz's Avatar
Hooooooonda.....
Funny, Mine has been just sitting in the engine bay for almost a year on the current car and it was like that on the old car for over two years. You either broke it, shorted it, cut a wire, or it wasn't plugge into the connector.
Old May 31, 2005 | 05:54 PM
the reason to replace a thermistor w/ a resistor is...................a resitor is $.25 and a iat is $40! mine broke so i went the cheap way. i know it doesnt effect the way a car runs and i just wanted my cel off. did you know the default setting is -40degrees when your iat is broken! so if lowering the iat sensor temp. was beneficial then unplugging it would yield the most gain however it yeilds no gain ever so i will try to phrase things diffrently next time!
Old Sep 1, 2006 | 03:37 AM
maxine'sMan's Avatar
what type of resistor would one use to replace this sensor with? I am getting a CEL from mine on my 97/99.. Is this the sensor right @ the airbox? or is it the one on the snorkle the feeds the box that comes from below and bends around to the front near the hood opening?
220k+ A32
Sep 11, 2015 02:18 AM
Maxboy23
Sep 9, 2015 10:37 AM
lux97Max
Sep 4, 2015 05:42 PM
