help...strut problem...
Old May 27, 2005 | 08:31 AM
Dayle97SE's Avatar
I recently hit a large pothole in NYC which bent my front right strut. I ordered a new one from KYB (I replaced the entire suspension system myself a few months ago, so this was very frustrating) and when I went to remove the old I found out that the strut mount insulator also broke. As a result I can't remove the strut piston nut, because the whole piston also spins. How can I remove the piston nut?, anyone else have this problem before?
Old May 27, 2005 | 08:36 AM
maxgtr2000's Avatar
KH3 by popular demand
Haven't had this problem but you probably need to just remove the whole assembley (strut with spring attached and possibly compressed for more room) and put it in a vise along with a small pipe wrench and cheater bar to hold it while someone else unscrews the nut.
Old May 27, 2005 | 09:36 AM
Dayle97SE's Avatar
there's really no place to put a clamp or vice grip, can't really get a hold on the piston
Old May 27, 2005 | 12:58 PM
maxgtr2000's Avatar
Have you compressed the spring yet with spring compressors?
Old May 27, 2005 | 01:11 PM
Dayle97SE's Avatar
yeah, even still
Old May 27, 2005 | 02:42 PM
BEJAY1's Avatar
Conecarver
No way to grab the piston at all? What about carefully cutting off the nut entirely (while compressed of course) and then replacing it?
Old May 27, 2005 | 04:30 PM
njmaxseltd's Avatar
Use an impact gun to get the nut off. Hold the piston with a vice grip plier, there's plenty of room to get the vice grip onto the piston.
If you hit a hole hard enough to bend the strut you definately bent the control are as well. At the body shop, we would also replace the hub and bearing on an impact like that.
Old May 27, 2005 | 08:17 PM
maxgtr2000's Avatar
The only other thing I can think of is if there is room to get a hack saw on trhe piston at all and saw it off while the spring is compressed, you have a replacement strut so basically you are just wanting the spring and a few other items that mount with it that you can't get off(strut bearings,etc). Good luck, if not try to get a quote for removal from a machine shop or something.
nadir_s
Apr 15, 2003 09:51 PM
Cabowabo
Dec 11, 2002 02:02 PM
nadir_s
Jul 23, 2002 01:11 PM
lorddeceiver
Aug 6, 2001 06:23 PM
