weird wheel noise
Old May 28, 2005 | 07:33 PM
mrgreek's Avatar
weird wheel noise
hey guys....sorry i cant be too detailed on this cause i dont really know wheel stuff....i hear this noise when driving low speeds, but it proly occurs at high speeds too, i proly just can hear it...
its got a rhythm and sounds like 2 metal pieces are sorta sliding beside each other, its not rough really, but it doesnt sound healthy...i can proly make the sound it makes with my mouth on sound recorded if i can host it somewhere,,,,i dont know that stuff....it sorta makes a hiss hiss noise with a rhythm...could it be breaks? bearings?
by the way....if this is something easy and its in the how-to's i apologize because im at work and i only get a short stab at the computer next door...thnx in advance
Old May 28, 2005 | 07:42 PM
suicidalspd99
you kow i hear the same thing. but only at times. i have not had the tme to really check it out. i think it is just the breaks. i hope not the wheel bearings. let me know if you find ne thing more
Old May 29, 2005 | 06:07 PM
mrgreek's Avatar
ya i will....bump...any1 else?....i also thought it was the breaks,,,,but i could have sworn it wasnt too long ago when i got them replaced....
Old May 29, 2005 | 06:11 PM
Bobo's Avatar
Ah if it isn't, mrgeek, lol! Maybe you could entertain us with the sound recording.
Do you hear the noise when the brakes are being applied? If so, perhaps you are down to the wear bar on the brake pads and may have only replaced one set so far.
If not, then it might be a wheel bearing problem.
Old May 29, 2005 | 07:09 PM
el_muchacho_qc's Avatar
Check pads wearness. Also, rotor might have overheated a bit and maybe he distorted (not sure if that's an english word but...) so it can be rubbing against pads somewhere in its revolution. If you feel vibrations in your steering at high speed, get the wheel correctly balanced. While you're there, check air pressure. If its nothing of that, could be wheel bearing. Good luck
alahjahwan09
18
Sep 21, 2015 09:12 PM
Bonka
Sep 14, 2015 11:18 PM
thenewguyy
Sep 12, 2015 11:12 AM
bennuss
Sep 11, 2015 05:55 AM
jfl330
Sep 4, 2015 01:44 PM
