ecu
Old Jun 1, 2005 | 07:49 PM
bklynzsleepy's Avatar
ecu
my max has been starting up weird lately. after turning the key, i gotta step on the gas in order for it to turn on. it's like a cold start problem but its been so warm these days in NYC and i'm having these problems. i brought the car to nissan to do a check on it and they tell me that i need a new ECU and a starter.
does anyone where can i get a new 99 ECU for cheap?
ECU at the stealership cost ~800 bucks.
Old Jun 1, 2005 | 07:51 PM
kasemodz's Avatar
maybe try cleaning your throttle body, it helps. I had a similar problem too and it kind of went away now since its almost summer but I cleaned my throttle body and from then on it worked fine.
Old Jun 1, 2005 | 08:06 PM
i30ds's Avatar
Armed and Dangerous
Good God man DO NOT LISTEN TO THE DEALER!!! Do a search on hard starting... just about every body that has taken their car to the dealer for this problem has been told they need a new ecu. Some actually bought it and it still did not correct the problem. Never did it actually solve anything. Trust me it is not your ecu!!! And it is not your starter! If it cranks and gives a good effort, then the starter is working.
I currently suffer from the same problem and I WILL find out what it is. There are several thing you can do to fix it:
1. replace the fuel filter and spark plugs if it has not already been done.
2. clean out your tb and iacv... it is supprising what this can do...
3. If you are still having problems then it is diagnostic time... have a QUALITY independant shop look at the following: engine coolant temp sensor, camshaft positon sensor (PHASE), crankshaft position sensor (POS), fuel pressure regulator... all of these can cause a hard/no start/ restart problem.
Old Jun 2, 2005 | 12:41 AM
blinelaxd27's Avatar
hey bro actually if you need a 99 ecu i am going to be selling mine in like a week after i get a 96 ecu to send to jwt
Old Jun 2, 2005 | 05:22 AM
Thanks for the tip i30ds.
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
Dasmith
Sep 23, 2015 08:28 PM
QueensMAX
Sep 15, 2015 04:14 AM
