Coils fine?
Old Jun 2, 2005 | 03:23 PM
InsneDrmr's Avatar
Coils fine?
Today I check my coil packs with the multimeter...everything read the same so I guess they are ok. I also turned the car on and unplugged the coils, each one caused an effect on the idle. I checked the coilpacks, are there more other than the ones underneath the plastic cover where the oil goes in? Are my spark plugs possibly bad?
Old Jun 2, 2005 | 04:18 PM
njmodi's Avatar
Do I get a tax break?
6 coils - 3 where you checked and 3 in the cylinders towards the firewall... your car is a V6 - you have one coil for each cylinder.
Old Jun 2, 2005 | 04:51 PM
InsneDrmr's Avatar
how do i get at them...are they covered?
Old Jun 2, 2005 | 05:04 PM
Amarao's Avatar
if the 98 Intake manifold is anything like the 95 one they should sit in between the gaps in the manifold.
Old Jun 2, 2005 | 05:09 PM
InsneDrmr's Avatar
i just checked the back coilpacks by the firewall...all seem to be working, but the car started throwing 0201...could it be because the coils were unplugged? or was it because of the bad one being disconnected?
Old Jun 2, 2005 | 05:11 PM
DcMaN's Avatar
its because you unplugged the coil packs while hte car was running simply reset the ecu.
Old Jun 2, 2005 | 07:14 PM
InsneDrmr's Avatar
I did reset it, and the code was thrown again. Then I reset it a second time, the light started blinking while the engine was running. Reset it a third time, and it finally went away. So, anyway, my coil packs are fine, but its the final problem I could possibly have? Unless its the spark plugs. Any ideas?
Cars runs sluggish when accelerating, and in between 2k-3k. This seems to be a common problem.
Old Jun 2, 2005 | 07:34 PM
CleanMAX98's Avatar
yep mine also
Old Jun 2, 2005 | 07:41 PM
InsneDrmr's Avatar
I have replaced my MAF, and KS. Both of which everyone had said that problem was. Now the only thing left would be the coils and/or spark plugs....this has to be it.
Old Jun 2, 2005 | 07:44 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
recheck your connections. and make sure the harness's are tight. if you have close to 100,000 miles or better. and youve never replaced your coil packs, now is a good time to do it. they are a wear item.
Old Jun 2, 2005 | 07:46 PM
CleanMAX98's Avatar
they are madd loot.... lol
Old Jun 2, 2005 | 07:54 PM
InsneDrmr's Avatar
all the connections are fine, and theres no code being thrown now. Never was with the exception of tonight. I got close to 70,000 on mine.
Old Jun 2, 2005 | 09:35 PM
Amarao's Avatar
261k miles on my original coil packs I was looking into getting some new Mitsubishi ones but at $330 for all 6 I think I might put it off a bit longer. lol
Old Jun 2, 2005 | 09:40 PM
Fork's Avatar
Maximaler Experte
It's all in the stickies above - plus, there's a nice writeup in one of the posts on changing coils. Just do a search...
Old Jun 2, 2005 | 09:45 PM
f550maranello2's Avatar
dude pull out fuel pump fuse, pull out the coil pack, ground the plug to the car and watch the spark that i will tell you if its good or not.
Old Jun 3, 2005 | 10:31 AM
InsneDrmr's Avatar
Or you could check it with a multimeter... I imagine that would be smarter.
Anyway, has anyone thought about going to a shop about this problem? It seems to be common.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
gigabyte
Jan 6, 2017 06:05 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
