has anybody regreased their starter?
i am in the process of putting my starter back together. when i took it apart, there was a rubber piece in the shorter chamber that just fell out and i don't know which way it was set in there. anybody help? also where did you put grease and did it work?
Originally posted by emax95
I've never heard on anyone rebuilding a starter before. The problem probably has nothing to do with grease, more likely it is a part inside the starter that has died. Just go out and buy a new one. BTW even if you did somehow fix the starter chances are it would just brake on you again. Check around your local auto parts stores because a new Nissan one is probably way over priced.
Originally posted by deezo
Dude why don't you send it to me. I'll get it back together.
yo, you won't believe this. i was trying to put everything together so i can put it away and every piece i put in somehow just fell into place, and that rubber piece was in-between the 2 compartments. everything is together and i'm gonna try it in the morning. i'll let you know how it goes.
I knew you were ****ed when you just broke out. I was like "damn" then I turned the PC off went turned on the TV to watch Martin. I hope I did help you out some tho. Good luck.
Thanks, man
mikeg75
Nov 30, 2015 05:12 PM
maxima297
Sep 30, 2015 03:32 PM
homewrecker
Sep 23, 2015 03:41 AM
