loose belt?
Old Jun 4, 2005 | 08:11 AM
mendon99's Avatar
tastey wheat
loose belt?
Lately ive been hearing what sounds like a loose belt, it quietly squeels when the car is idle. Nothing overwhelming, but just enough to be annoying.. is there some belt that commonly comes loose on our cars that can be tightened easily??
Thanks for the input.
Old Jun 4, 2005 | 08:21 AM
THT's Avatar
THT
Throbbing member
yes, they can be tightened very easily. There is a 14mm adjuster just above the idler pulley. Tightening it will push the idler pulley down, causing the belt to tighten. You may need to loosen the bolt holding the idler pulley though before the adjuster can do it's job properly. This is what I'd do:
1. Check the belt for cracks or other indications of wear. Replace if necessary
2. To tighten:
a. Loosen the bolt holding the idler pulley. You want it just tight enough so the pulley cannot wiggle on the bolt.
b. Tighten the 14mm adjuster so the belt's deflection is proper
c. Tighten the nut holding the idler pulley
Old Jun 4, 2005 | 10:34 AM
mendon99's Avatar
tastey wheat
thanks man, tried it and it made the squeels much softer, still there but thats only becuase my belts are really cracked. thanks!
D Mason
Jun 21, 2016 04:43 AM
markevans999
Oct 25, 2015 08:27 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
homewrecker
Sep 24, 2015 07:01 PM
2kmaximel
Sep 24, 2015 03:55 PM
