I messed somethig up :(
Old Jun 11, 2005 | 07:21 PM
HarrisH's Avatar
My god damn LED in the ignition switch started flickering, the LEDs that that guy CWITCHIK or whatever is selling are GARBAGE I've had to replace atleast 5-6 of them, anyways, I accidently touched the positive and negative saw a little spark and the fuse went out, I replaced the fuse, NOW... my dome light DOES NOT come on when I open the doors. It only comes on when I manually switch it to "ON". I've tried 3 diff. LEDS and ALL of them ARE EXTREMELY DIM when I put them in the ignition switch socket, also my ashtray LED is no longer working either. What can this be . It's ticking me off...
Old Jun 11, 2005 | 09:24 PM
HarrisH's Avatar
BUMP Anyone? Please?
Old Jun 11, 2005 | 09:39 PM
Black Maxima
Welcome to the I fried my BCM club...
Old Jun 11, 2005 | 09:45 PM
Zack342's Avatar
i got one for sale
Old Jun 11, 2005 | 09:50 PM
Black Maxima
How Much???
Old Jun 11, 2005 | 09:56 PM
konak85's Avatar
thats what you get for ricing out a maxima.
j/k
Old Jun 11, 2005 | 10:03 PM
Black Maxima
j/k
HAHAHA. That's the truth and this is even gheyer:
Old Jun 11, 2005 | 10:10 PM
tekneekzz's Avatar
ok first of all the ignition switch light is a bulb which means ull need a resistor on the led to keep it lit without any problems.. secondly the reason the dome light prolly doesnt work now is you fried a fuse..
u just gotta kno what yer doing.. cwithk's led's are good.. i re did my entire interior with his led's
Old Jun 11, 2005 | 10:14 PM
Black Maxima
I used cwithk's LEDs all the time. This time it was user error. I did use a resistor, it was a tight fit and the prongs touched. And it's not as easy as a fuse. I check every fuse there is, even the wireing, tried some diagnostic modes also. The dealer said part of the BCM is toast.
Old Jun 11, 2005 | 10:42 PM
DAVE Sz's Avatar
Hooooooonda.....
Why are you blaming CwithK when it was your fault? It's a piece of plastic with 2 pieces of short, metal leads. I've had his LEDs for a while and since I knew what I was doing they are still fine.
Old Jun 12, 2005 | 01:19 AM
kbmaxima's Avatar
this is why i didnt insert the metal prongs into the socket, i inserted them on the outer part of the metal tabs so that there would be no way for them to touch or short out, even if it were to fall out.
Old Jun 12, 2005 | 07:16 AM
HarrisH's Avatar
His LEDs are bad, I replaced the Hazard Switch LED already, replaced the manual a/c controls atleast 4-5 times and no those were not user errors, the LEDs would start flickering, and eventually go out... any other suggestions?
Old Jun 12, 2005 | 07:49 AM
Black Maxima
His LEDs are not bad...
Old Jun 12, 2005 | 07:52 AM
HarrisH's Avatar
I got a bad batch as did some other people that I know...
Old Jun 12, 2005 | 08:28 AM
TJ_Max's Avatar
Paradox Systems Vendor
How the hell do u get a bad batch? He hand picks 50 leds that don't work and give them to u??
Honestly, if they r bad, get a resisted led and attach it to the battery and see if it goes bad.....
When ure led flickers it means the two legs touched or YOU ARE NOT USING RESISTORS or the correct resistors....I use his leds all the time also....u messed up, admit it....and who else got a bad batch??? Give me his email address....come on man, stop being ignorant, u didn't get a bad batch.....
Old Jun 12, 2005 | 08:40 AM
HarrisH's Avatar
SonicDust187 did my LEDs he had some bad ones, WARIOW, the flickering LEDs WERE NOT TOUCHING, the resistors I used were the resistors he gave me, when I tested them on my battery my phone battery they were still flickering...
Old Jun 12, 2005 | 10:57 AM
RA030726's Avatar
I'm nutty for Nissans
a bunch of mine did the same thing. i did everything in my car. then i had a buddy do a 2nd dome light. even though he solders for a living they started to flicker. he did a really nice job, but after a few weeks they started to **** the bed. it may or may not be the parts, could just be too much heat with the iron or something we do to screw them up. all my red ones work perfect. its the white ones that go crazy. they were in my dome light and climate control.
Old Jun 12, 2005 | 12:17 PM
HarrisH's Avatar
I have all whites as well...
Old Jun 12, 2005 | 01:39 PM
kingrukus's Avatar
no more maxima...
Old Jun 12, 2005 | 04:43 PM
HarrisH's Avatar
Originally Posted by kingrukus
White LEDs look 100000 times more better than the crappy stock ones, blue is rice IMO, white is more stock...
Old Jun 12, 2005 | 04:47 PM
Black Maxima
I'm about to change mine to white. I'm getting tired of blue. Now that I am a master at soldering in LEDs. HAHAHA 3000-4000 mcd is way to bright for me at night...
Old Jun 12, 2005 | 05:27 PM
tekneekzz's Avatar
dang lol and i thought 7000 was bright.. my ****s are so blinding when i drive at night.. (it was my first time dealing with leds so didnt kno how different the brightness was in number so i bought 7000 mcd) hahah
Old Jun 13, 2005 | 06:53 AM
laylow1988's Avatar
[QUOTE=HarrisH]My god damn LED
litch
123
Jan 4, 2024 07:01 PM
wyobbagy
Jan 3, 2023 12:03 PM
homewrecker
Sep 24, 2015 07:01 PM
msellas
Sep 23, 2015 09:16 PM
Colossus
Sep 9, 2015 05:46 AM
