got some ECU codes - multiple cylinder misfire and knock sensor
98 GXE with 74K miles on it. When I had it in for service at 69K miles the mechanic said that the starter was bad, so I'm wondering if that is what is rearing its ugly head. I also haven't replaced the spark plugs in quite some time so I'm wondering if that could help. As far as the knock sensor goes, I'm not sure if that is related or if it is a separate error. Back when my mechanic said that he could replace my starter, he quoted me something like $400 for the starter - any place I could get one cheaper if that's what needs to be done?
You say the spark plugs haven't been changed in quite some time. Have they ever been changed? They probably didn't need to be changed quite some time ago as in all likelihood the OEM NGK platinum plugs were probably in place, but they may in fact need replacing now. If they need to be replaced, use only NGK platinums or coppers.
If the starter motor truly needed to be replaced at 69K, I doubt it would have lasted to 74K. What makes your mechanic think it requires replacement?
I had some problems a while ago with the engine misfiring once in a blue moon, but it would appear that the problem had sorted itself out. The mechanic said it was the starter motor, but I opted not to have it done due to the high price and the fact that it wasn't giving me much hassle. I have not personally replaced the sparkplugs, but I got it used from a dealer at 39K miles, so I'm not sure of the status of them. Would the spark plugs be the first to look at? Can I get NGK platinums or coppers at a local autoparts store? Thank you very much for your help, let me know if you need any more information.
i try my hardest not to go to a mechanic to save alot of money and DIY is way more fun u can do your starter too im sure of it
0701 - multiple cylinder misfire
0304 - knock sensor failure
The misfires probably triggered the knock sensor failure - so I wouldn't rush and replace the knock sensor just yet.
You can buy a rebuilt starter for 150-200 bucks. Replacing it yourself is easy - the toughest part is breaking one of the bolts loose. See www.motorvate.ca for instructions on removing/replacing the starter.
The CEL light will turn off then back on sometimes, whatever it said was wrong is still there. NGK plugs you usually have to order, unless someone has them in stock, I got mine from NAPA NGK laser platinum $13.?? each! But I the plugs I took out were the cheapest BOSCH plugs out there. I think its worth it in the long run. And you should do it yourself its pretty easy.
EDIT as far as multiple cylinder mis-fire I would check your electrical connections to any part that has to do with the cylinder itself, like coils, connectors to coils, make sure you don't have any bad fuses, I personally don't think that all or multiple of your sparkplugs, or coils, or injectors would all just go bad at once. I would guess it is something bigger that controls one of those components. Just my 2 Cents
ballerchris510
09-23-2015 08:46 PM
