Anyone else have fitment problems w/ their ebay fstb?
Old Jun 13, 2005 | 01:32 PM
NCSU_MAX's Avatar
Maximoneypit
Anyone else have fitment problems w/ their ebay fstb? (Pics)
well i ordered an "SPW" FSTB off ebay and tried to install it today and cannot get it to fit. its adjustable but the bar will not clear the wires over the intake manifold. anyone know what to do - thanks guys.
me and my max the past 2 weeks --
1. exhaust begins to leak AGAIN (3rd time) and my car sounds like NASCAR
2. KS dies and my car begins to ride like crap - i lose to an integra off the line
3. my shifter keeps hitting the trim in 3rd.
4. 9007 conversion actually works - after i have to buy new bulbs because one dropped and broke.
4. Strut Bar FINALLY comes and it doesnt fit.
ohhh how i love modding
Old Jun 13, 2005 | 02:05 PM
NCSU_MAX's Avatar
Maximoneypit
heres what im talking about - its rubbing the throttle cables. is it supposed to be this tight?
Old Jun 13, 2005 | 04:30 PM
RA030726's Avatar
I'm nutty for Nissans
thats the wrong bar, its supposed to be bent a bit at each end.
Old Jun 13, 2005 | 04:38 PM
blackmaxx96's Avatar
There's never a day when something's not on sale
I had kind of the same problem with mine Grant... Just angle the bar back, and put washers under it... thats what I did... sorry to hear about all your troubles man..
Old Jun 13, 2005 | 05:40 PM
FishyMan's Avatar
not supposed to rub, try playing with it, washers, or adjusting it.
Old Jun 13, 2005 | 05:45 PM
WielkiWaac's Avatar
MaximaDriver
no. i didnt have any
Old Jun 14, 2005 | 12:54 PM
NCSU_MAX's Avatar
Maximoneypit
ok thanks guys - yea mike i was thinkin about that but i was wondering if the bar would perform as well if it wasnt flush with the top of the struts mounts. i mean, i know they dont do a whole, whole lot to begin w/ but i wasnt sure. i think ill put the washers in tho bc i dont like the looks of it being so close to those cables and such.
Old Jun 14, 2005 | 12:59 PM
kormax97
If you don't do something quick and keep driving that thing around, first thing that'll brake is your EVAP cannister purge control valve, AKA, $70 little plastic round thing.
Make sure you have a good 1/2 inch at least from those hoses.
Old Jun 14, 2005 | 01:07 PM
BigLou93SE's Avatar
Funny you should mention that...
Today I installed mine, and I had to unhook the bracket for this hosing/piping (refer to pic; bracket bolt is circled, pipe has arrow going to it, background arrow pointing to spot that this hose goes into the firewall) to make it fit. I put a piece of rubber under the strut bar to keep from scratching the metal pipe.
I'm going outside right now to see if my fitment was as tight, but I don't think it was IIRC.
Old Jun 14, 2005 | 01:10 PM
NCSU_MAX's Avatar
Maximoneypit
ooooh - thank you. good info
Old Jun 14, 2005 | 01:17 PM
NCSU_MAX's Avatar
Maximoneypit
yea mine fits just barely around there.
BigLou93SE's Avatar
Ahhhh, well I just checked, and it isn't REALLY tight, but the throttle cables are touching mine, and that evap cannister doesn't have a lot of room either. So get some washers?
Old Jun 14, 2005 | 01:22 PM
RA030726's Avatar
the a/c hose can be bent out of the way fine. almost all FSTB have that problem. the throttle cables and evap can be moved slightly but not enough for that bar. seriously contact that seller and get the correct bar.
Old Jun 14, 2005 | 01:26 PM
NCSU_MAX's Avatar
Maximoneypit
yea i did contact him and im waiting to hear back. i bent the piece holding the evap cannister down a little and it seems to clear fine (didnt really want to do that though)
Old Jun 14, 2005 | 02:34 PM
BigLou93SE's Avatar
Well, I went out and bought washers, and when installing them, 4 out of the 6 torqued correctly, but then when I got to the other two, it felt like the bolt stripped. One won't even unscrew now, either. But I do have more clearance now...
Old Jun 14, 2005 | 06:34 PM
JPMax's Avatar
What's next!?..
OK, just checked the bars that Racing Dimension sells on eBay.
It looks like you bought the $12 straight JDM bar. (Or they sent this one to you by mistake.)
They also sell another model with the bends at the ends for $19.
You should see if you can exchange what you have for the other model. It will give you more clearance room.
Old Jun 15, 2005 | 01:16 PM
NCSU_MAX's Avatar
Maximoneypit
oooooooooo thank you. good call - i didnt even see that.
Old Jun 15, 2005 | 01:49 PM
RA030726's Avatar
so now your screwed out of 2 ($30?) strut mounts for a $20 egay bar?
Old Jun 15, 2005 | 01:55 PM
BigLou93SE's Avatar
Is that what I'm going to have to replace? It was only on one side. Any suggestions on how to get these nuts off now?
Old Jun 15, 2005 | 02:58 PM
StalkerGDL13's Avatar
mine fits tight like that too, the seller i bought it from is just a couple blocks from me, im gonna check with them to see whats up.
Old Jun 16, 2005 | 05:41 PM
RA030726's Avatar
if they wont come off, as if the bolt is spinning, you will need to cut or break the nut. im not sure if the bolts in the upper strut mount can be replaced, but they look pressed in like wheel studs. so there may be a cheap fix. but still a bar should fit 100% no modifications. but it does look good.
Old Jun 17, 2005 | 04:40 AM
BigLou93SE's Avatar
IIRC, the bolt isn't spinning, just the nut is.
They don't feel loose, or untorqued, though. I had my torque wrench set at 32 ft-lb and it just felt as if they had gotten to a certain torque setting (probably around upper 20-low 30 ft-lb), and can't tighten anymore. They don't spin without resistance, they just don't tighten. Nor loosen for that matter. After driving like this a couple of days, and constantly checking to see if this is causing any trouble, I figure that I'm ok to drive like this (car feels solid), and the problem will come when I want to install my suspension, which looks like it won't happen before I go to college.
In response to the bar fitting correctly, I paid $4.95 plus shipping for this bar, so I never thought that it would fit 100%. However, I don't think my problem came because of the strut bar modification (washers), it kinda just happened, and I don't believe that it was the bar's fault that 2 of the nuts are now stuck.
Mar 12, 2020 12:06 AM
londonflu
40
Sep 25, 2015 09:11 AM
Colossus
Sep 9, 2015 05:46 AM
slowlifer
Sep 8, 2015 05:53 AM
