Clucth lost pressure???? why?
Old Jun 13, 2005 | 04:58 PM
ManualMaxima's Avatar
5th Gen till she dies!
I was driving down the street today and and my car started getting hard to shift. After alittle while the clutch pedalwhen i pushed it down went straight to the floor and stayed there. I turned the car off and pushed it in and pulled t out and it got better. What went wrong here?
Old Jun 13, 2005 | 06:13 PM
VQ of Bodom's Avatar
Could be air in your clutch lines, might need bleeding.
Could be your TO bearing.
Could be your clutch disc.
How new is your clutch? How do you usually drive your car?
Old Jun 13, 2005 | 06:39 PM
my clutch has maybe 25,000 miles on it. i do nto drive my car real hard. i am aggressive sometimes but not to much.
Old Jun 14, 2005 | 04:25 AM
MAXRB8's Avatar
Probably your clutch master or slave cylinder, when you get a new clutch it has a tendancy to put more pressure on these parts than the previous clutch. 50/50 odds but I'm guessing it's your slave.
Old Jun 14, 2005 | 05:14 AM
crazy97's Avatar
I had this almost happen over the weekend. I was losing a lot of fluid. Turns out there was a 'wet' hose located under the air scoop, a rubber hose that plugs into the tranny. It's about 10 inches long. I bought a new one at the stealer $50. Put it on yesterday and the leak is GONE! I need to bleed the line some more but I definitely found the cause.
Old Jun 14, 2005 | 05:18 AM
sdoherty_tjm's Avatar
have you guys ever done a controlled launch or w/e from like 4k and had the clutch get all weird and not come out?
Old Jun 14, 2005 | 05:32 AM
cardana24's Avatar
Blown
check your slave cylinder....I bet its dry. Mine did this as well, and I just added a little DOT3 until I could get around to replacing the slave cylinder (its easy do do your self). After I replace the slave cylinder I was still have a problem with loosing fluid, so I replaced the clutch line (rubber hose going to the slave) and it fixed the leak. Goodluck.
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
gigabyte
Jan 6, 2017 06:05 PM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
msellas
Sep 23, 2015 09:16 PM
