Squashed Progress springs
Old Jun 14, 2005 | 06:30 PM
maximaah's Avatar
I put on new rotors yesterday and noticed that my Progress springs in the rear are sitting on the top 5 turns, so basically are doing nothing. (The rear beam was sitting on jacks.)
Is this normal?
Here's what they looked like before the install (two on left are the front springs):
Old Jun 14, 2005 | 07:04 PM
maxgazm's Avatar
time to get new springs
Old Jun 14, 2005 | 07:13 PM
86maxima96's Avatar
I Broke OT
huh... is that normal? how long were you riding on them? do you have a system in back?
Old Jun 14, 2005 | 07:20 PM
njmaxseltd's Avatar
Yes, thats normal.
Nismotic's Avatar
Always sunny in philly
I'm not sure whether or not mine sit like that, but that doesn't look right.
Old Jun 14, 2005 | 07:27 PM
Kevlo911's Avatar
Kevlo for President
Mine look like that too.
Old Jun 14, 2005 | 07:57 PM
dmBK's Avatar
How 'bout them cliffs?
yup, my Progress springs are the same way. the fronts dont look much better, either.
Old Jun 14, 2005 | 08:56 PM
Who's Avatar
Who
When I jack the body of the car(=> spring fully extended) the top set of coils look pretty close(<1cm) so I guess if you jack the beam that would be how it should look. I had put spots of silcone between the upper coils to prevent them from touching and cutting away the paint. The silcone is still there today and there is no evidence(missing paint) of the upper coils touching.
Old Jun 15, 2005 | 04:13 AM
maximaah's Avatar
Thanks for the replies. If anyone can post pics of theirs, I'd be interested in seeing them (jacks on beams, of course). BTW, my fronts are not squashed like that.
Old Jun 15, 2005 | 01:36 PM
86maxima96's Avatar
I Broke OT
that's cuz when you raise the front, you are taking all of the stress off of the shocks and springs whereas when you raise the rear on the beam, the weight of the car is still being transfered to the ground through the beam, which causes the springs to depress. it's probably normal. raise it somewhere where it doesn't affect the beam, and then look.
Old Jun 15, 2005 | 01:56 PM
NCSU_MAX's Avatar
Maximoneypit
heres what mine look like for reference sake
sorry - i didnt feel like takin the wheel off but you get the idea.
Old Jun 15, 2005 | 01:59 PM
RA030726's Avatar
I'm nutty for Nissans
progressive rate springs touch, eibach, intrax, tokico, CMS...... all normal. its just the way they work.
Old Jun 15, 2005 | 04:59 PM
86maxima96's Avatar
I Broke OT
teins are progressive also, right? s and h techs?
Old Jun 15, 2005 | 05:05 PM
aznsap's Avatar
ya i have s techs and it looks similar to that. should be okay.
Old Jun 15, 2005 | 05:11 PM
Maximeltman's Avatar
look at the picture that you posted of them BEFORE you installed them. Now doesnt it come looking squashed on one end??
Old Jun 15, 2005 | 05:30 PM
NCSU_MAX's Avatar
Maximoneypit
yes - they are supposed to look like that. to maintain a certain spring rate and ride height, the distance between coils will vary between different springs.
Old Jun 15, 2005 | 06:22 PM
maximaah's Avatar
Thanks, guys, I conclude that everything is A-OK.
Old Jun 16, 2005 | 05:31 PM
RA030726's Avatar
just about every spring avilable for maximas are porgressive rate, meaning more than one working spring rate... basically variable. they are made for the street, so under normal driving the rates are low (softer). when you push the car into a corner the rates become higher (stiffer) and body roll is decreased.
linear springs have one working spring rate, ie: 300 in/lb coilovers.
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
MaxiNoob98
Oct 2, 2015 10:13 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
followthadollar
Sep 27, 2015 01:06 PM
