Drive axle NEED Help
Old Jun 17, 2005 | 07:40 PM
maxedout95's Avatar
I tried to chage my passenger drive axle on a 98 maxima. I almost got it but i was not able to pull it out from the transmission no matter how hard i pulled on it. Is there a way i can do it?
thx
Old Jun 18, 2005 | 04:45 AM
njmaxseltd's Avatar
You have to unbolt it from the carrier bearing.
There are 3 bolts on it, once you get them out pry the axle out of the bearing, the rest is simple.
Old Jun 18, 2005 | 05:57 AM
maxedout95's Avatar
i did unbolt the 3 bolts but still couldn't get it out. I don't know where to leverage it from. THere is almost no room. Where is the best place to pry it from, what would you use to pry it.
Old Jun 18, 2005 | 10:43 AM
nick's Avatar
use a sharp chisel and slowly pry on the axle bearing bracket, spary some PB blaster on it and give it few minutes to penetrate, the axle might be seized up in the bearing bracket and that is why it is hard to get it out, once you free the axle from the bracket , just pull on it and it should come out of the tranny, there is no C-clip holding it in , ( driver side has C-clip)
hope this will help
Nick.
Old Jun 21, 2005 | 07:30 PM
maxedout95's Avatar
thanx for the help. i read your reply after i replaced the axle but I did it the way you explained it though. I guess great minds think alike.
PH98I30
29
Feb 10, 2025 12:03 PM
boomerbrian
Oct 31, 2018 10:25 AM
captchaos
Mar 15, 2016 12:18 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
