Who has a fifth gen exhaust.
Old Jun 20, 2005 | 05:52 PM
konak85's Avatar
Just wanna know if it is a direct bolt-on without alterations. I need one soon.
Old Jun 20, 2005 | 05:54 PM
NmexMAX's Avatar
dot dot dot ...
Everything's essentially the same besides the muffler. As far as the manifold/y-pipe, you're better off with the 4th gen pieces.
Old Jun 20, 2005 | 05:56 PM
Jatan's Avatar
If you're talking about the muffler, the hangers will line up fine, but you'll have to get it welded to your pipe
http://forums.maxima.org/showpost.ph...48&postcount=5 (last pic shows where I had it welded on)
Old Jun 20, 2005 | 06:30 PM
maxS
5th gen y-pipe is a bit longer...
Old Jun 20, 2005 | 07:48 PM
1FSTMAX's Avatar
no its not.. same thing..
Old Jun 21, 2005 | 12:19 AM
TrackSmart's Avatar
What's the best way to pick one up on the cheap? I haven't been fully satisfied with my Warpspeed "dynomax clone" muffler. Decent "growl" and good airflow, but it looks worse than the stock muffler (it's really huge and fat - so it doesn't tuck nicely under the car).
Any suggestions?
Old Jun 21, 2005 | 01:11 AM
Umass021's Avatar
What year should it be taken from?
Old Jun 21, 2005 | 09:26 AM
Pimpmobile's Avatar
What note does the 5th gen produce compared to stock, and say a straight through type?
Old Jun 21, 2005 | 09:32 AM
Bobo's Avatar
I keep a data base on these replacement parts/issues for when I confront them and my notes say get a 2001 muffler. I'm not sure why that's recommended over a 2000 muffler but evidently one of the selling features of the 01 muffler is it supposedly looks better.
Old Jun 21, 2005 | 01:28 PM
ManualMaxima's Avatar
5th Gen till she dies!
i have one form a 2001 max.....2000-2001 look differant from 2002-03...i do not know the exact differance in them though...but they all will fit
Old Jun 21, 2005 | 01:48 PM
konak85's Avatar
Hey manual, did it fit on without any welding and cutting, was it a direct bolt on without any problems?
Do you just have the muffler or the other piece too? Also do you need gaskets?
Old Jun 21, 2005 | 02:02 PM
i just have the muffler.....i took it to a muffler shop and it had to be welded on. They also had to make some hangers for it. It cost like $50 to get it on there. But it is quiet and IMO looks much better than the stock one, so it was worth it.
I just did not want anything with sound...
Old Jun 21, 2005 | 02:15 PM
Ladzio's Avatar
I changed mine to 2K2 as well. Wanted some quietness. Paid $100 for used muffler.
Old Jun 21, 2005 | 02:17 PM
Jatan's Avatar
lol got mine for $35 shipped
Old Jun 21, 2005 | 02:37 PM
Rowan's Avatar
I think mine is a 2002 model (2 seperate tailpipes where as the 2001 model is 2 tail pipes connected). Not sure of the years exactly.
Had to get it welded on.
See my cardomain page for more (and rate my page while you're there! )
Old Jun 21, 2005 | 02:41 PM
Brudaddy's Avatar
The 5th gen muffler fits on the stock hangers, but I believe the pipe inlet is on the opposite side as the stock one.
When I had mine put on, I think they flipped it around, and then they just welded it onto the stock piping.
Sounds a little deeper though. It is great!
Old Jun 21, 2005 | 09:16 PM
konak85's Avatar
Thanks for the input guys, then i guess 02-03 would be fine also.
Old Jun 21, 2005 | 09:24 PM
konak85's Avatar
The only thing thats holding me back is that the fifth gen double exhaust tips will look weird on the stock 4th gen rear bumper cut-out. Brudaddy, how'd you make the cut out on your? recipricating saw?
Old Jun 22, 2005 | 08:55 AM
BlackCat's Avatar
RIP '98 Maxima SE
I read on Brudaddy's cardomain site that its not necessary to cut a hole for the double exhaust tips as it hangs lower than our 4th gen tips.
Hmmm...a brainstorm...now that's got me thinking about how to fill in that semi-circle opening....get a scrap piece of bumper, cut it with a dremel to fit and then paint it to match?
Old Jun 22, 2005 | 09:47 AM
Donald199's Avatar
so did you guys felt any difference at all?
sound wise?
i remember seeing a post saying it MIGHT net you 1 horse lol
Old Jun 22, 2005 | 11:18 AM
BlackCat's Avatar
RIP '98 Maxima SE
sound wise?
I heard that it would be good for boosted Maxes.
Old Jun 22, 2005 | 11:35 AM
TrackSmart's Avatar
I don't have this particular muffler, and I'm not boosted, but I think that when you are boosted, air-flow becomes WAY more important than when naturally aspirated.
I'd imagine that a boosted maxima would want more flow than a 5th gen muffler affords. I may be wrong on that, so don't quote me.
Old Jun 22, 2005 | 11:39 AM
NmexMAX's Avatar
dot dot dot ...
Boosted or not it will not net anything worth writing home over, maybe 4 hp MAX
Old Jun 22, 2005 | 11:42 AM
4DRSpeed's Avatar
Project Ruby......
Or maybe that boosted and n/a maximas can both use 5th gen mufflers since a muffler is only there to produce sound.
Old Jun 22, 2005 | 11:44 AM
TrackSmart's Avatar
Agreed. Probably zero or one HP for naturally aspirated. More if boosted, just b/c airflow is increased. But what boosted maxima would be running a stock muffler! Unless they really enjoy a quiet ride?
Old Jun 22, 2005 | 11:51 AM
yea but what muffler give you worth while gains anyways? now a cat-back might but not just a simple weld on muffler. nothing on the butt dyno. Honestly i do not think the double tip looks bad on the opening.....i guess most of you are perfectionists but you really do not notice it unless you really care about it......
i got mine not for the gains which i knew there was none. I just wanted a better lookng muffker that was as close to stock sound as i could get.....i have never seen a bumper someone cut looking that great either.....
Old Jun 22, 2005 | 01:21 PM
NmexMAX's Avatar
dot dot dot ...
Headers -y/pipe give most horsepower gains ... Anything other than that is not worth the hassle. Unless you're like 96sleeper and have a cut-out. But that's for racing purposes only, so unless you track your car regularly, b-pipe and muffler have no buisness getting replaced.
Old Jun 22, 2005 | 02:53 PM
Brudaddy's Avatar
I would not use a recipricating saw....it is too bulky.
They guy that did mine royally screwed it up.
In hind sight, I would just take a rasp or file or dremmel or something like that to do it. I know it would take a little bit longer, but it would look a lot better. Mine is not exactly straight.
Keep in mind, there doesn't need to be much of a whole. The 5th gen muffler....at least the one I got.....hangs down a little further than the stock one under the bumper. Just make the tallest part of the original hole....stay the tallest part.
Old Jun 22, 2005 | 02:55 PM
Brudaddy's Avatar
sound wise?
It frees up the whole setup.
I have an aftermkt y and larger piping....so I would guess all that with the 5th gen muffler gave me about 20hp gain.
It sounds a lot better to me. It is not that much different, but it just growls a little deeper.
Old Jun 22, 2005 | 03:15 PM
Brudaddy's Avatar
Yeah, boosted needs more air flow than just a muffler, but the 5th gen is just about as free flowing as you can get out there.
It is just a lot cheaper and better looking than some others.
Old Jun 22, 2005 | 03:16 PM
Brudaddy's Avatar
You are right about that.
Doing nothing else but muffler will not get you anything really.....except sound differences.
Old Jun 26, 2005 | 07:02 PM
konak85's Avatar
Should i just get the rear section or the whole catback, what ya think?
Old Jun 26, 2005 | 07:38 PM
craig10114's Avatar
personally i think the best setup would be a full exhaust with a stock 2k+ muffler... looks stock but packs the same punch
Old Jun 26, 2005 | 08:13 PM
Brudaddy's Avatar
Well, a high flow cat does nothing. You get no gains from it and you just get worse emissions out of it.
Just get 2.5" piping from the cat back and 2000+ muffler.
MAXSE5SPD
Sep 17, 2022 04:00 AM
ik95
Sep 16, 2015 08:11 PM
ballerchris510
Sep 10, 2015 09:35 PM
A32goldylocks
Sep 2, 2015 06:39 AM
